Heinno
« on: January 23, 2011, 11:10:26 PM » |
Hi All
Got the pipes today - wanted to install, but the holes in the bracket that bolds onto the head seems too close - it should be an easy fix, but I was wondering - is this normal?
Also, does the baffles in these pipes make a huge difference in sound - thinking of going straight pipes.
Any advice welcome, I am new at this
wdvalk
« Reply #1 on: January 24, 2011, 03:18:47 AM » |
Mine bolted up nicely.had to play with the hanger bolts a little,you will lose back pressure ,resulting in less hp if you take the baffles out,but it will be louder,mine are loud with the baffles in
Bugslayer
« Reply #2 on: January 24, 2011, 03:28:11 AM » |
Are you using new gaskets? It sounds like you're either using the same gaskets, or none at all.
Heinno
« Reply #3 on: January 24, 2011, 08:42:15 AM » |
The bolt studs (on cylinder head) do not line up with the fastening plates' holes on the pipes. Seems to be (holes in the plate) about 4mm too narrow. I can ream the holes, but it seems rather strange that this would be needed.
SCain
« Reply #4 on: January 24, 2011, 09:05:03 AM » |
If the plates are curved just slightly, thats your problem. Try straightening the plates and they should bolt right on.
Steve
Redline +
« Reply #5 on: January 24, 2011, 09:12:52 AM » |
Yes, considerable difference in sound. Personally, as an old hot rodder/drag racer, I loved the open pipes... but not for long distance. On my bike, on the dyno, removing the baffles increased both hp and torque by 5. I now use stock pipes. Redline
Heinno
« Reply #6 on: January 24, 2011, 11:27:57 AM » |
[/quote]
Did you rejet? Everybody seems to be saying that removing the baffles would reduce HP.
Heinno
« Reply #7 on: January 24, 2011, 11:36:30 AM » |
Thanks, I have noticed they are slightly curved, but did not think that would be enough effect the hole positions - will see if I can straiten them out, and if solves the problem.
Brad
« Reply #8 on: January 24, 2011, 11:41:56 AM » |
I take the baffles out every year when street vibrations comes to town. Lot's of HD boys making lots of noise during that rally so I have to show them that the Hondas can make some noise too.  If I am riding a distance I put the baffles back in. It takes less than 10 minutes to remove or replace them.
Heinno
« Reply #9 on: January 24, 2011, 12:03:34 PM » |
I take the baffles out every year when street vibrations comes to town. Lot's of HD boys making lots of noise during that rally so I have to show them that the Hondas can make some noise too.  If I am riding a distance I put the baffles back in. It takes less than 10 minutes to remove or replace them. Do you notice a power difference in baffles "in" vs "out?"
Redline +
« Reply #10 on: January 24, 2011, 12:23:17 PM » |
Did you rejet? Everybody seems to be saying that removing the baffles would reduce HP. [/quote] The Cobra pipes were installed by the original owner. I don't think it has been jetted, it may have adjustable needles. I've had no reason to look at the carbs yet so I don't know. I could feel the difference in power with the open pipes and the chassis dyno confirmed my butt dyno. Redline
Heinno
« Reply #11 on: January 24, 2011, 01:01:04 PM » |
Redline
Thanks, sounds like your carbs was tuned with the baffles out by the previous owner. How many miles do you get on a tank?
Bugslayer
« Reply #12 on: January 24, 2011, 01:40:01 PM » |
My bad. I thought you meant the bracket's were too close to the head..... Duh..
Redline +
« Reply #13 on: January 24, 2011, 01:42:46 PM » |
Redline
Miles per tank will vary widely depending on tank size, how full you fill your tank and of coarse your right wrist. I average probably 37 miles per gallon, close to 40 a few times, can't stay outa the throttle! I have put 5.1 gallons in my 5.2 tank twice at just under 200 miles... filling stations sometimes are few and far between. Redline
Brad
« Reply #14 on: January 24, 2011, 03:21:18 PM » |
I take the baffles out every year when street vibrations comes to town. Lot's of HD boys making lots of noise during that rally so I have to show them that the Hondas can make some noise too.  If I am riding a distance I put the baffles back in. It takes less than 10 minutes to remove or replace them. Do you notice a power difference in baffles "in" vs "out?" I do not notice any difference in power. My neighbors car alarm notices a difference in the sound
« Last Edit: January 24, 2011, 03:22:51 PM by Brad »
Heinno
« Reply #15 on: January 24, 2011, 03:29:03 PM » |
I do not notice any difference in power. My neighbors car alarm notices a difference in the sound  [/quote] LOL - THAT IS ALWAYS FUN! ESPECIALLY IN AN UNDERGROUND PARKING LOT!
Heinno
« Reply #16 on: January 24, 2011, 03:32:31 PM » |
My bad. I thought you meant the bracket's were too close to the head..... Duh..  NOPE - The holes seem too close to each other - the stud screws seems to be further apart than the holes in the plate - will ream them, should not be too hard. The pipe ends fit nice and snug into the heads - cant wait to hear her roar!
shank
« Reply #17 on: January 24, 2011, 06:01:02 PM » |
are you trying to put your pipes on assembled? two of them stay together the other one removes from those two. i had the same problem. basically had to separate to get them to line up. kind of a pain, you will need an extra hand. make sure to put new exhaust gaskets in. use a little bit of grease to hold them in place. tighten the back last. and personally i like the sound with baffles out. long ride or short i want to hear it. lol
olddog1946
« Reply #18 on: January 24, 2011, 06:57:27 PM » |
I have cobra pipes and when I did my first rear tire removal I took the exhaust off the bike...(didn't know any better) and had trouble putting them back on..had to install one at a time, which worked fine..there were no gaskets in the pipes, just about a pound of red rtv, which was a bitch to remove..I installed new gaskets and had one hell of a time putting the nuts on..could just barely get them started. Don't forget to recheck the nuts a few times or you will be losing them..ride, check , ride, check.. Personally the bike sounds like a porsche on steroids, but I find it a bit loud for an old fart..I added some muffler wrap to the baffles, which knocked it down a bit..still pretty loud..
I must also mention that my splines were bone dry..I doubt they had ever had any kind of grease/paste put on them..SO, DO INDEED, check yours..
VRCC # 32473 US AIR FORCE E7, Retired 1965-1988 01 Valk Std. 02 BMW k1200LTE 65 Chevelle coupe, 1986 Mazda RX-7 with 350/5spd, 1983 Mazda RX-7 with FOMOCO 302/AOD project, 95 Mustang GT Convertible 5.0, 5 spd Moses Lake, Wa. 509-760-6382 if you need help
Heinno
« Reply #19 on: January 24, 2011, 10:52:44 PM » |
No, the pipes line up, even if assembled - the 2holes on each fastening plate do not line up with the bolt studs next to the exhause outlets on the head. I can fix it, but is seems strange - almost like the plates is made for a different kinda bike. All the other screw holes line up well with the pipes in place.
Bone
« Reply #20 on: January 25, 2011, 02:11:28 AM » |
Wonder if the plate was put on upside down before welding during mfg. ?
« Reply #21 on: January 25, 2011, 03:37:29 AM » |
If you want the noise, you lose power, to each his own, you won't notice it without a dyno, or if you race your buddy with the stock pipes on his Valk!  hoser  Stock pipes
« Last Edit: January 25, 2011, 03:40:48 AM by Hoser »
Heinno
« Reply #22 on: January 25, 2011, 09:21:03 PM » |
If you want the noise, you lose power, to each his own, you won't notice it without a dyno, or if you race your buddy with the stock pipes on his Valk!  hoser  Stock pipes Naah, not enough Valks around my neck of the woods - just a bunch of Harleys - no problem then LOL!
« Reply #23 on: January 26, 2011, 05:07:44 AM » |
You are correct, sir, as I said, to each his own.  Hoser
Heinno
« Reply #24 on: January 26, 2011, 09:58:45 AM » |
You are correct, sir, as I said, to each his own.  Hoser Thanks for the dyno pic - does your bike (the one on the dyno) have bigger jets, or just cobra pipes?Seems a small difference. Except for power building.
Reb
Greeneville, TN
« Reply #25 on: January 26, 2011, 10:09:25 AM » |
If they are new pipes, For a couple extra $$$ you can get the inside of the pipes ceramic coated, which will greatly decrease the amount of bluing that takes place on them. I don't know how well it works, but always wanted to try it.
2022 Honda Goldwing Tour DCT 1999 Honda Valkyrie IS 1997 Honda Valkyrie Standard *Supercharged* 1972 Honda CB350F 1978 Honda CB550K 1968 Honda CL175 Sloper
« Reply #26 on: January 26, 2011, 01:18:58 PM » |
You are correct, sir, as I said, to each his own.  Hoser Thanks for the dyno pic - does your bike (the one on the dyno) have bigger jets, or just cobra pipes?Seems a small difference. Except for power building. That is a stock 99 Valkyrie with stock exhausts, piggies cut, with a truck stack exhaust cover and grumpy's tips. It turned 94 horsepower with out the grumpy's tips on it, so I'm leaving them on, 5 hp gain. Thanks Bill! Hoser
