February 01, 2026, 05:58:42 PM *
Author Topic: No Turn signals  (Read 1524 times)
BIG--T
The Twilight Zone
« on: January 24, 2011, 09:12:01 PM »
Maybe I've been bragging on my baby too much! I just brought her home tthis evening and noticed I have no turn signals. The indicator doesn't blink either. I assume the fuse box is in a side cover or under the seat.
If it's not a blown fuse, any suggestions what else to check? If I had a loose connection on one light, would it cause all not to work?
Thanks in advance cooldude
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #1 on: January 25, 2011, 01:32:19 AM »
i think the fuse for turn signals is behind the right side cover.
BIG--T
The Twilight Zone
« Reply #2 on: January 25, 2011, 05:43:32 AM »
Thanks Goose, I definatly need to get a service manual!  Smiley
« Reply #3 on: January 25, 2011, 08:42:02 AM »
Maintenance on the actual switch on the handlebars is the usual fix.
The switch grease gets hard and stops any electrical contact.
very common on the Valkyrie.
« Reply #4 on: January 25, 2011, 05:16:04 PM »
If it isn't the grease as Ricky-D suggests, start chasing the green GROUND wire for the turn signals.
Usually no ground however, you have a dim light.  BUT, it could still be a bad ground.
