March 21, 2026, 08:25:26 PM *
Author Topic: Try these in your concealed carry or home defense weapon.  (Read 1512 times)
Marcel
« on: January 26, 2011, 06:33:07 PM »
COR BON DPX 380ACP/80gr. Jug Test Using The Bersa Thunder 380powered by Aeva
It may just make the difference.
9mm and this is pretty ugly, but you need to see what this round can do.
It is absolutely dependable and cutting edges are magnificent in demonstration.
AT1 - 9mm Luger - DPX - Cor-Bon 115 Gr +P JHPpowered by Aeva
« Last Edit: January 26, 2011, 06:44:20 PM by Marcel » Logged
¿spoom
WI
« Reply #1 on: January 26, 2011, 08:54:49 PM »
Interesting, thx. The bullet seems a little long on the 9mm unless it's the photo angle, I assume it has to be at the max length for the specific round. Curious because my .380 Bersa seems to digest everything but my LCP doesn't like the more truncated Federal "hydra-shok" even thought the similar Hornady "critical defense" feed fine. Suppose there's only one way to find out. Would've liked to see a few more common rounds shot for comparison like FMJ Ball rounds & one of the ones above.
« Reply #2 on: January 27, 2011, 02:01:16 PM »
check out bersachat.com. Alot of ammo jug/denim tests done on alot of different. Alot of the 'good' brands fail.
¿spoom
WI
« Reply #3 on: January 29, 2011, 12:15:23 PM »
Thanks!
http://www.bersachat.com/forums/forumdisplay.php/66-Ammo-Jug-Tests?s=e898527ac1dbdcd2325d13f5af307dac
« Last Edit: January 29, 2011, 12:18:21 PM by ¿spoom » Logged
Marcel
« Reply #4 on: January 31, 2011, 05:47:54 PM »
Very Helpful link.
Now I know all hollow points are not created equal.
Thx.
