February 01, 2026, 07:40:52 PM *
Author Topic: Car tire for the first time - darkside question  (Read 3812 times)
Daro
« on: January 27, 2011, 12:38:30 PM »
Hi everyone on the Darkside  Wink
I am going to put car tire on my Valk for the first time. Searched Tech Board - 21 pages of threads.
I've read GL forum and Vulcan forum and I am confused. Please HELP  Undecided
Which tire - winter, summer or all season?
Some of the threads are old (2007, 2008) - which car tires are actually the best for Valk?
Which tire on front - Dunlop, Avon, Metzeler?
I've decided not to modify rear fender - is the 205/55/16 the only size?
#3165 VRCC
03 Valk Standard
99 Interstate Supercharged
03 Valk Supercharged - for sale
« Reply #1 on: January 27, 2011, 03:00:54 PM »
New meat, Darksiders!  Come an git it!  Get ready Daro   cooldude  Hoser
chip
« Reply #2 on: January 27, 2011, 03:28:05 PM »
 Oh boy opening up that big a$$ can of worms ! But I'm listening this time my IS is due and I'm tired of buyng those expensive tires.
Cliff
Manchester, NH
« Reply #3 on: January 27, 2011, 03:32:31 PM »
Goodyear triple tread is one decent option
VRCC # 29680
« Reply #4 on: January 27, 2011, 03:42:13 PM »
I like a soft compound directional pattern...I use both a Copper Zeon 2XS rated 280 and a Fuzion ZRi rated 320 on my bikes. Both stick outstanding in the twisties and great on wet roads.
waterman
1999 Interstate
Laurel, MT
« Reply #5 on: January 27, 2011, 03:53:38 PM »
Had a Bridgestone on my Interstate for about 700 miles and could not feel confident, but then I don't have many flat straight roads around here.
You can't save people from themselves
Thunderbolt
Worthington Springs FL.
« Reply #6 on: January 27, 2011, 03:54:44 PM »
I myself thought the guys running a car tire must be crazy.  But after buying several motorcycle tires that flattened out in the middle anyway, decided to give it a try.  Over 10000 miles on it now and it still looks like new and guess what, it's flat in the middle too.  Matter of fact, it's flat all the way across!!!!  When my wife rides on the back she says it rides better too.  I did the carriage bolts from the inside and the washer mod to pull the fender out on the right side a little.
« Reply #7 on: January 27, 2011, 05:16:08 PM »
Modify the fender now istead of having to pull it apart later to do it.
It don't take that long and then no worries about the tire rubbing.
Daniel Meyer
The State of confusion.
« Reply #8 on: January 27, 2011, 05:23:06 PM »
http://lifeisaroad.com/stories/2004/10/27/theDarkSide.html
CUAgain,
Daniel Meyer
« Reply #9 on: January 27, 2011, 05:24:06 PM »
My research found that the 1st tire of choice was the Goodyear Assurance Triple Tread is the closest to stock MC size of 205/55R16. This is an all season tire. It has 3 tread patterns for 3 different conditions.
You can go up/down one size, 60 or 50. If you do this, your speedometer will no longer read correctly. If you go larger to the 60, then you'll almost always need to do the Nut Cage Mod.
I talked with one guy about this tire, and his recommendation was NOT to go this way, that because it has 3 zones, it also has 3 different handling zones.
After the 1st tire is tried, then the sky is the limit. I think most like a snow tire, because using it during the summer it grips the road better, being made of softer rubber.
I've already bought and installed my Goodyear TT to a spare rim. After I go through this tire, I'll just look for a good rain tire (maybe winter) that has a nice rounded edge.
« Last Edit: January 27, 2011, 05:26:56 PM by gordonv » Logged
Daniel Meyer
« Reply #10 on: January 27, 2011, 05:29:40 PM »
If we're talking Valks, this is not correct. Speedo reads the front wheel.
CUAgain,
Daniel Meyer
« Reply #11 on: January 27, 2011, 05:43:47 PM »
Sorry, you are right. It was the RPM I should have referred too.
JC
The Beast
Franklin, TN
« Reply #12 on: January 27, 2011, 06:55:46 PM »
Eh??
If we're talking Valks, shouldn't have referred to RPM either, that reads engine speed......
valkmc
Idaho??
Ocala/Daytona Fl
« Reply #13 on: January 27, 2011, 07:16:11 PM »
Eh??
Changing the rear tire hieght will change the rpm at any particular speed, cruising at 80 mph will have slightly different rpms for a 55, 60, or 65 tire.
2013 Black and Red F6B (Gone)
2016 1800 Gold Wing (Gone)
1997 Valkyrie Tourer
2018 Gold Wing Non Tour
Ken Tarver
North Mississippi
« Reply #14 on: January 27, 2011, 07:35:56 PM »
goodyear TT 205/60-16 ~ nut cage mod
the sixty profile is going to be the closest to stock tire diameter ~ nut cage mod is very easy, just go ahead and do it
F6CTrider
Denver, Colorado
« Reply #15 on: January 27, 2011, 10:35:44 PM »
A big DITTO  cooldude
goodyear TT 205/60-16 and the nut cage mod
Went to the DARKSIDE 17000 miles ago, love the look and the smooth ride, handles just fine.
Next time I will be trying the taller "65" to "improve" the RPM/Speed/Mileage "thing". uglystupid2  Won't know until a few years go by, it looks like I will get 60K out of the Goodyear.  (And yes, the tire has been off, and the splines are well lubed)
Daro
« Reply #16 on: January 27, 2011, 11:37:31 PM »
First of all thx for precise response.
I decided to buy Cooper. What PSI do you ride them? Are they 205/55 or 205/60 ?
#3165 VRCC
03 Valk Standard
Daro
« Reply #17 on: January 27, 2011, 11:42:23 PM »
tried to find this tire on ebay...also onlinetires... nothing...zero  Undecided
#3165 VRCC
03 Valk Standard
« Reply #18 on: January 28, 2011, 03:15:14 AM »
http://www.tirerack.com/tires/TireSearchResults.jsp?width=205/&ratio=60&diameter=16&startIndex=0&search=true&pagelen=20&pagenum=1&pagemark=1&manufacturer=Goodyear&x=19&y=12
Bone
« Reply #19 on: January 28, 2011, 03:22:06 AM »
I'm on my 3 rd. CT with the last two being Goodyear TT 205/60-16 ~ nut cage mod
The CT fits my riding style and is a good ride going cross country. Handles wet conditions very well.
Daro
« Reply #20 on: January 28, 2011, 05:41:54 AM »
tried to find this tire on ebay...also onlinetires... nothing...zero  :-
Thanks.  cooldude My mistake  Embarrassed I was looking for " goodyear TT" not "triple tred"
#3165 VRCC
03 Valk Standard
Ken Tarver
North Mississippi
« Reply #21 on: January 28, 2011, 05:49:56 AM »
 sorry Daro ~ I lead you astray with the abreviation TT
us385south
"Geeky White Caucasion"
San Marcos, Texas
« Reply #22 on: January 28, 2011, 06:48:37 AM »
I spent years reading about this before I finally, "broke on through to the other side."
Goodyear Assurance Triple-Tread here.  I have a very detailed gallery that might interest you here:
http://www.culleynet.com/zen/1998-valkyrie-tourer/
Let me say a few things:
1. I can understand why this might not be good for everyone, I have to admit that it does feel a little squirrelly sometimes when I am pulling in and out of parking lots.  Nothing too hairy, but you have to watch yourself.  Or at least i do...
2.  It stops GOOD!
3.  Expect to spend time defending yourself from people who have never ridden on a CT.  It seems to me that folks who are most passionate about this are folks who have never ridden a Valk... or any bike with a car tire.  It's like taking to those Christians that knock on my door on Saturday mornings, they seem to "want" to convert me.  They seem to feel that I need to be "saved" from my own ignorance.  What's so funny about these people (in both cases) is that I usually end up outclassing them in hard knowledge and my observations based on 42 years of riding... and a lifetime of being raised Quaker.  ( I particularly like it when I have to help them find the verse they are trying to quote to me!  That always tickles me... )
 4.  CT's are just different... I like mine!
« Last Edit: January 28, 2011, 07:28:12 AM by us385south » Logged
"I can't explain a blessed thing,
not a falling star or a feathered wing,
but when the light's just right I swear I see...
poetry!"
Daro
« Reply #23 on: January 28, 2011, 07:55:45 AM »
2.  It stops GOOD!
Big thanks ! Wise words! (about tires too)  cooldude
#3165 VRCC
03 Valk Standard
F7daved
Detroit
« Reply #24 on: January 28, 2011, 10:08:02 AM »
I did the same thing multiple times, going back and forth. I finally decided to go with the General Ultimax Hp 205/60/16 I Did the nut cage as well, with the wheel of and a die grinder took 15 minutes. Quote me here I LOVE IT AND WILL NEVER GO BACK.  Been to the dragon 3 times and have no problems. I was told of all the tires listed this on had the best V shaped, though that was just a couple guys opinion here.  I have ridden my buddies with a good year and i personally think there is a small difference. I think also the most part is getting the correct pressure front and back. That makes a HUGH difference how the bike handles. I would not go with the 55 series at all due to the little bit difference in rpm and fuel consumption.  Just my 2cents  cooldude
« Reply #25 on: January 28, 2011, 10:19:16 AM »
Did I screw up on my recalection again? The 60 profile is the closest to stock, so one size up down, 55 and 65
SPOFF
Derry, NH
« Reply #26 on: January 30, 2011, 08:57:42 AM »
And if we're talking Valks the speedometer doesn't read correctly anyway. As for RPMs, the tach follows the ignition. A different sized tire will change the RPM at any given speed, but the tach will be as accurate as it was (or wasn't) before the tire change.
olddog1946
Moses Lake, Wa
« Reply #27 on: January 31, 2011, 10:45:52 AM »
I have a federal 535 tire on my bike...it has a directional tread, which to me makes the most sense..I would think a bi-directional tire would make the handling different going to right and left..may be wrong (frequently am,lol)...at any rate whatever tire chosen will require some experimentation on air pressures..I started at 32, moved up 2 psi at a time til I found my sweet spot..of 38 or 40 depending on ambient temperatures..
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
Gangman036
Terre Haute, IN
« Reply #28 on: February 04, 2011, 05:19:10 PM »
GYTT 205/60/16 w/ nutcage mod.................easy.
