November 22, 2025, 09:08:46 AM *
Author Topic: Russell SS brake lines  (Read 1593 times)
OP2
Ohio
« on: January 28, 2011, 06:00:18 PM »
Does anyone know where I can buy Russell SS brake lines for a 99 IS? I have been looking and have mainly seen front lines for the IS, and rear lines for the standard and tourer. Do the rear ones interchange between models? Do I have to eliminate the block that the front lines run into when I go to the SS lines? What about the clutch side? Any other suggestions / comments are appreciated.
Paul
shortleg
maryland
« Reply #1 on: January 29, 2011, 04:57:01 AM »
  Galfer makes all the lines you will need.
The fronts replace the block with a new one.
And then the clutch and rear brake are also
well made.
            Shortleg[Dave]
fordmano
San Jose, CA.
« Reply #2 on: January 29, 2011, 03:01:29 PM »
YEP, Galfer makes all the lines.
You can find the full set (Front, Rear & Clutch) with a Bottle of DOT4 Galfer brake fluid for $199.99 on E-Bay. That's what I picked up and the look good and fit good also, sitting on the lift they also feel better (brake lever firmness that is).
But to answer your question, No I have not had any experience with the Russel lines for brakes but I have found that Russel makes some awesome automotive lines and fittings.
Good luck with your project.
83GS550
93XR650L TARD!
97WR250
99ValkyrieI/S Tri-tone
01YZ125(x2)
05DRZ-125
John U.
Southern Delaware
« Reply #3 on: January 29, 2011, 06:39:22 PM »
I bought two sets of Russel rear lines. Both are labeled  "Part No. 09551 "Rear Brk Line Valkyrie VN-P# R09551S". One of them has a second lable that says "R09551S 97-98 Honda Valkyrie/ Tourer/ Interstate (Rear) CC", they are the same length and have the same fittings at each end.
I plan to use one set on a standard and another on an I/S but haven't gotten around to it yet. They look to be comparable in quality to the Galfers.
OP2
Ohio
« Reply #4 on: January 30, 2011, 09:59:57 AM »
Thanks for the help Brothers. I will look into finding the parts numbers for the Russels. Another member told me he had a problems with the Galfers rusting after moister got on them is why I was looking into the Russell brand. Anyone else running this brand have this trouble?
Garry 2r's
Rothbury MI
« Reply #5 on: February 11, 2011, 05:56:55 AM »
Has anyone tried this set or know about them?
http://cgi.ebay.com/ebaymotors/Honda-Valkyrie-1500-96-01-Brake-line-kit-Front-Rear-/250490836946?pt=Motorcycles_Parts_Accessories&hash=item3a526ad7d2
Thanks Garry
