February 01, 2026, 07:39:52 PM *
Author Topic: Wolo horn mount help  (Read 2768 times)
Sourdough
Tucson
« on: February 02, 2011, 06:26:53 PM »
I just got a Wolo air horn for my 01 I/S and not sure where to mount it. I have
fog lights in my pods, so I don't think it will fit in there. Any ideas, suggestions,
or photos would be appreciated. Maybe this is the wrong style air horn for an I/S ?
01 I/S Black/Beige
97 Standard Bumblebee
Divot
Retired - VRCC #30489
Boise, Idaho
« Reply #1 on: February 02, 2011, 10:02:55 PM »
I suppose it depends on whether you are trying to hide it or not.  I have a chrome one and I made a right angle bracket and mounted it just in front of the fuel shutoff valve on my Standard.  The horn sits perpendicular to the length of the bike and as I recall there is a threaded bolt there you can use to mount a bracket to.  Looks good there to me.
2000 GL1500C - Black
1980 Honda 185 XL
Joe Hummer
Arnold, MO
« Reply #2 on: February 03, 2011, 05:05:43 AM »
For a hidden application, I mounted my wife's under the swing arm.  The plate there is just a filler and you can use self-tapping screws on it to hold your bracket in place.
1999 Valkyrie Interstate
vanagon40
Greenwood, IN
« Reply #3 on: February 03, 2011, 07:32:03 AM »
Probably close to what Divot described
Kaiser
Gainesville, FL
« Reply #4 on: February 03, 2011, 07:41:59 AM »
Mine (Stebel) is attached via a bracket to the kickstand cross-member (sorry, no pics).  If you go that route, make sure it won't interfere with a lift adapter.
Disco
Republic of Texas
« Reply #5 on: February 03, 2011, 08:18:38 AM »
Here's mine.  I do have to pull two wires and loosen one nut to pull the horn out of the way of the lift adapter, but the bracket stays in place.  Do a search for more horn mounting locations.  If I remember correctly, look for a pic of STEELERS setup.
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
« Reply #6 on: February 03, 2011, 10:42:15 AM »
That's it, only get a chrome one.  cooldude  hoser
Divot
Boise, Idaho
« Reply #7 on: February 03, 2011, 02:39:03 PM »
Yep, those two are in the same location as mine.  Mine is just turned 90 degrees.
1980 Honda 185 XL
fordmano
San Jose, CA.
« Reply #8 on: February 03, 2011, 08:46:37 PM »
About like this, I have a 12V outlet mounted right there kinda behind and beside the Stebel.
I tried a couple times to mount it in the pod and I have the factory fog lights and there is NO way I found to make it fit in a Pod.
Although if you can't see the 12V outlet, thats because I removed it temporarily during this reinstall this afternoon.
FYI,, I actually had to touch up my Chrome Stebel since it has sort of lost its shimmer. I found this Chrome like paint that is definetly NOT chrome but it is a very shiny silver more like semi polished aluminum. So if yours is not chrome and you end up putting out in the open you may want to consider a little spray job.
« Last Edit: February 03, 2011, 10:26:10 PM by fordmano » Logged
83GS550
93XR650L TARD!
97WR250
99ValkyrieI/S Tri-tone
01YZ125(x2)
05DRZ-125
vanagon40
Greenwood, IN
« Reply #9 on: February 04, 2011, 09:04:07 AM »
. . . .  So if yours is not chrome and you end up putting out in the open you may want to consider a little spray job. . . .
But I thought the consensus was that black was fastest.
« Reply #10 on: February 04, 2011, 11:32:39 AM »
Only to a misguided but very nice group that do not appreciate the vivid colors of the rest of the model line.   Cheesy  Evil  hoser
