January 28, 2026, 11:22:45 AM *
Author Topic: miss firing  (Read 3369 times)
art
Grants Pass,Or
Grants Pass,Or
« on: April 07, 2009, 03:18:54 PM »
I need help.My 2002 standard with 100000 mi. is running lousey at cruising speed .At about 45mph an holding it at a steady speed it starts to missfire an run ruff .this gets worse as the engine gets hotter up to running temp.I have checked the plugs an the are a br/grey..the vac. tubes look goodwith no cracks.I have run seafoam an no change.I'm thinking bad coil or bad plug wires.I have cut the piggies an instaled a 6% trigger wheel an get about 36 mpg two up with windshield at highway speeds.Help please an thanks.Art in Or.
YardBoy
« Reply #1 on: April 07, 2009, 03:27:28 PM »
Thats where I'd start, might be a little easier once  you indentify the bank or specific cylinder/cylinders thats misfiring.
SCain
Rio Rancho, NM
« Reply #2 on: April 07, 2009, 03:39:15 PM »
I would start by draining the fuel from the tank and carbs, get some fresh fuel preferably without ethanol and see how it runs before doing anything else.
I had an experience with a tank of bad fuel, ran great cold but when the engine got up to temp the fuel started to gel.
Just my .02
Steve
art
Grants Pass,Or
Grants Pass,Or
« Reply #3 on: April 07, 2009, 04:09:28 PM »
the fuel is not an issue .I have this problem for several months an a lot of different brands of gas with no change .I went on a 300mi. ride yesterday with two tanks of gas from two diff. areas with no change an got 36mpg. Art
« Reply #4 on: April 07, 2009, 04:15:03 PM »
You say the vacume lines look good.  How did you "look" at them?  Have they ever been changed?  Also I would be concerned that this could be petcock problems......those OEM valves seem to be worthless by 100,000 miles
« Reply #5 on: April 07, 2009, 05:29:30 PM »
If it runs good and you get 36 mpg, then I think you can eliminate any problem with the ignition system. Electrical components are either good or bad w/ very little in between.
I'd look for vacuum leaks, lines and 'o'-rings.
Are the carburetors synchronized properly?
