March 07, 2026, 07:06:48 PM *
Author Topic: Seen this trailer on a Valkyrie ?  (Read 3496 times)
TWT
Aylmer Ont
« on: April 07, 2009, 07:56:19 PM »
anyone seen this trailer for Motorcycles? Not too big not too small, and actually quite nice.
www.thirdwheeltrailers.com
CRUZIN
Alberta
« Reply #1 on: April 07, 2009, 08:09:32 PM »
I pull a uni-go single whell trailer behind my Valk. I like the size and the amount of gear that can be put in the trailer. I realy like that I can wheel it into a hotel room and not have to chain it to a lamp post in the parking lot. but I have spent hours tring to stop the wobble problem. It is the tail that wages the dog. I have redsigned the hitch changed the tire to a different brand and it is better but the wrong rut in the road and BEWARE!! I don't think I will buy another one. I would never think of doing over 85 mph towing it
TWT
Aylmer Ont
« Reply #2 on: April 08, 2009, 07:53:58 PM »
I've had mine do (not recommended of course) 125 mph behind a Busa, and it was very solid and no wobble what so ever.
Lucky Duck
Inverness, FL
« Reply #3 on: April 08, 2009, 08:19:44 PM »
I've pulled my Uni-Go at 85MPH several times and have never had any tail wag.  The mfg says to adjust the height of the trailer nose a couple of inches higher than level, maybe that makes the difference.  If the trailer is empty and I get into turns pretty hard, the trailer will drift to the outside a little but I can't feel it -- I know that from what people behind me have said.  The fact that I can roll it into a motel room, even using the small elevator some motels have, is a real bonus!
CajunRider
Broussard, LA
« Reply #4 on: April 10, 2009, 09:28:48 PM »
I had the wiggles with my Uni-Go before...  I have noticed that loading heavy items on bottom makes a BIG difference.
My first load attempt had me wiggle at 75... I reloaded to optimize the weight and ran 750+ miles in one day at 90-95 without a single wiggle.
Since then, I've changed my shock bushings on the back... that may have been part of the problem also, cause they were BAD...
« Last Edit: April 10, 2009, 09:30:42 PM by CajunRider » Logged
Sent from my Apple IIe
CRUZIN
Alberta
« Reply #5 on: April 11, 2009, 08:29:03 PM »
Yes it pulls much better if I load it with the heavy stuff at the bottom I have learned that I find that if I put some of the load on the bike rack that also helps and if we ride two up the wagging is very managable. I have adjusted the hich up and down and I think I have it in the best position now.  I have been told by a unigo dealer that to lenghten the hitch by about 4 inches helps alot. but I have not tryed that yet.
