November 22, 2025, 09:08:47 AM *
Author Topic: Harbor Freight Tire Changer HELP!!  (Read 4438 times)
deckerjr
Albuquerque NM
« on: February 08, 2011, 09:44:35 AM »
Finally need the motorcycle tire changer from Harbor Freight and now they don't have it!! Made the mistake of thinking it would always be available. Does anyone out there have a spare they would be willing to part with? It's time to replace my darkside and no one around here will touch it. Got it on the old fashion way but I can't imagine getting it off the same way!!!
« Reply #1 on: February 08, 2011, 10:24:57 AM »
Where did you look?   It looks like they have about 5, some very expensive ones included.
http://www.harborfreight.com/automotive-motorcycle/wheel-tire.html
Brad
Reno, Nevada
« Reply #2 on: February 08, 2011, 10:31:05 AM »
Where are you located?  Someone might know someone that could help.
Kaiser
Gainesville, FL
« Reply #3 on: February 08, 2011, 10:40:11 AM »
If you have no intentions of every using the old tire again, hacksaw it off:
http://www.advrider.com/forums/showthread.php?t=299856
(The companion thread is really cool - it shows how to mount a new tire with no tools.  I stole this link from another VRCC-er's post).
PAVALKER
Pittsburgh, Pa
« Reply #4 on: February 08, 2011, 12:51:42 PM »
Hmmm, I didn't notice the MC wheel adapter on the HF website, like they used to have.  I have the tire changer and  I also had to get the MC wheel/tire adapter to use with that tire changer.... and I don't see that.     Undecided
I think that is what the OP is talking about.
John
« Reply #5 on: February 08, 2011, 01:51:17 PM »
I tried that. I didn't use straps, I used zip-ties, but as you can see, they held the beads essentially all the way
together all the way around... I woulda needed that lever that Archimedes was searching for to get both of those
beads on the rim at the same time... I can slip a bicycle tire on with a three inch plastic tire tool, I have to bust my
butt to get a Valkyrie tire on... I'd guess the advRider tire is somewhere in the middle...
I also tried it for getting the old tire off... I was real encouraged by how loose the tire was on the rim, they
were very much separated from each other... but I still was no match for two beads at the same time...
I don't mean to be negative... I wish someone would see what I did wrong and show us how to
do it with a Valkyrie tire... in the meantime, I've got some upgrade modifications for my bucket,
some new tire irons that are almost as gnarly as Archimedes' lever and a new tire to install,
pictures soon I hope...
Cliff
Manchester, NH
« Reply #6 on: February 08, 2011, 02:10:15 PM »
This tecnique (using large zip ties) Worked very well for me,, a little bead lube and hands force pushed both beads on.
VRCC # 29680
quexpress
Montreal, Québec, Canada
« Reply #7 on: February 08, 2011, 04:14:17 PM »
Well ... IMHO ...this is a good thing.
I took mine off (the MC wheel adapter) and stuck a long 3/4-inch bar in the middle of the HF tire changer. It now functions MUCH better than before.  cooldude
I still have a full deck.
I just shuffle slower ...
Walküre
Nothing beats a 6-pack!
Oxford, Indiana
« Reply #8 on: February 08, 2011, 05:43:29 PM »
When I was looking at getting one, I think they were just getting ready to stop selling them. The local (well, 45 miles away) Hf had one, and it was the floor model, and missing a part or two. They weren't important parts, as I recall, maybe a bolt and nut (easily replaced), or similar, but I wanted one in a box. If you want, I can check and see if they still have it, might sell it pretty cheap. Shipping of just that, shouldn't be too bad. i get over there, fairly often, so it's no biggie. Let me know, and I can give them a call...
R
2000 Valkyrie Standard
1999 Valkyrie Interstate
2000 HD Dyna Wide Glide FXDWG
Roger Phillips
Oxford, IN
VRCC #31978
Yeah, what she said...
« Reply #9 on: February 08, 2011, 11:25:55 PM »
I just checked this link out, only $40 for the cheap one. Would this work for our Valk rim and a CT?
« Reply #10 on: February 09, 2011, 06:16:21 AM »
On your Valkyrie?
-Mike "I'm a wimp"
deckerjr
Albuquerque NM
« Reply #11 on: February 09, 2011, 08:57:46 AM »
R
I would be interested if basically complete. email at pdecker18@comcast.net Thanks.
At my HF they had discontinued written on the picture of it hanging from the base unit. I have searched the net and found a more expensive heavier duty version available on eBay but want to exhaust all avenues for this one. I never saw the zip tie trick and that could be the answer.
deckerjr
Albuquerque NM
« Reply #12 on: February 09, 2011, 09:00:40 AM »
How does this work? Do you lock down the tire some way?
Ken Tarver
North Mississippi
« Reply #13 on: February 09, 2011, 11:13:22 AM »
deckerjr
rim clamps
