November 22, 2025, 09:09:49 AM *
Author Topic: Fuel line size? Tour Tanks.  (Read 1964 times)
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« on: February 08, 2011, 06:46:18 PM »
Thinking of purchasing a tank from http://www.coyote-gear.com/10inch.html.  I have the 10x14 with an end filler in mind.  I want to mount it on the Cobra solo rack of my bike.  Any opinions?
Also it is about ZERO degrees outside so does anyone know the fuel line size coming off the shut off vavle?  I figure I could "T" it in there.
What are your thoughts?
« Last Edit: February 10, 2011, 01:13:46 PM by Zeus661 » Logged
Dropbox is a neat app I found that I use to store files and pictures of my Valk.
9Ball
« Reply #1 on: February 08, 2011, 07:21:25 PM »
fuel line from petcock to "T" going to each set of carbs is 8mm (0.315")....5/16" (0.3125") is close, fits snugly, and does not require hose clamps.  3/8" is too big, but will work if you use hose clamps.
5/16" is available at any auto store.....no source for 8mm that I know of except OEM.
« Last Edit: February 08, 2011, 07:22:58 PM by jrhorton » Logged
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
« Reply #2 on: February 10, 2011, 09:01:22 AM »
Failure to use hose clamps on any fuel line is a recipe for disaster!
Regardless of how tight a hose may fit on a barb.
This is not intended as criticism.
9Ball
« Reply #3 on: February 10, 2011, 10:22:28 AM »
I wouldn't recommend it either and definitely use hose clamps.  My point was that it is a very snug fit to the point a hose clamp is only insurance with the 5/16" line.  The 3/8" line will pull off or leak without a good hose clamp and I wouldn't recommend that size for the fuel line, but it will work.
1999 Standard
2007 Rocket 3
2005 VTX 1300S
