November 22, 2025, 09:09:34 AM
Brake Lines
Topic: Brake Lines (Read 1278 times)
rampagerip
Central PA
Brake Lines
February 10, 2011, 08:27:16 AM »
Does anyone have any experience with dual front brake lines (dedicated single lines from master cylinder to caliper) vs stock set-up? I know the Galfer lines use the same single/ crossover set-up as the stock, but some other aftermarket suppliers use two dedicated lines. Any performance pros/ cons with either set-up?
Daniel Meyer
The State of confusion.
Re: Brake Lines
February 10, 2011, 08:57:31 AM »
I went with those on my bud's 81 'wing, the stock crossover on that bike was notoriously hard to bleed...like, nearly impossible...
They went on easy, were easy to bleed, and performed well.
CUAgain,
Daniel Meyer
Re: Brake Lines
February 10, 2011, 06:24:38 PM »
The Galfer lines use A crossover but not the same as OEM. I've had no problems with the Galfer set up. It's easy to bleed and the pads wear evenly.
fordmano
San Jose, CA.
Re: Brake Lines
February 10, 2011, 08:18:06 PM »
The only thing that worried me about the dual lines setup was the longer banjo bolt at the mastercylinder seems a bit weak for my taste, and I have heard of them breaking a bit easier when installing but other than that I like the idea of the 2 lines. I guess just be REAL carefull and do not over tighten.
What Exactly is Normal?
83GS550
93XR650L TARD!
97WR250
99ValkyrieI/S Tri-tone
01YZ125(x2)
05DRZ-125
=> InZane XXV
