February 01, 2026, 10:28:42 PM *
Author Topic: Ain't much left  (Read 3347 times)
« on: February 14, 2011, 04:02:32 PM »
to take off!
Jack B
Two Rivers Wis
« Reply #1 on: February 14, 2011, 04:26:44 PM »
Now that is a naked bike!
Let’s RIDE
« Reply #2 on: February 14, 2011, 05:41:28 PM »
dam dude didja make sumbody mad??
« Reply #3 on: February 14, 2011, 06:29:00 PM »
To keep the handlebars and most importantly...the master cylinders upright, you need to do something else. Get a piece of 1x1 about 3' long and lay it across the top of the frame, and under the switches/master cylinders on the handlebars. I then tie them down to the wood with some short bungee chords I happen to have.
« Reply #4 on: February 14, 2011, 06:29:47 PM »
Nope, new to me.  Had to go thru her.
« Reply #5 on: February 14, 2011, 06:31:33 PM »
John, I'm changing out all the fluids, don't think they've been done for a while, if at all.
« Reply #6 on: February 14, 2011, 06:51:13 PM »
Aaahh,  okay, umm were are they?   Undecided   I swapped out one valve cover, did valve clearance, timing belt adjust, new o rings, carb slows, oil & filter, coolant swap and I'm hoping I'm good with the motor till 2012.  Got lots to do till I ride her.
fordmano
San Jose, CA.
« Reply #7 on: February 14, 2011, 11:54:55 PM »
WOW!!! and I thought my project list was a bit overwhelming. Can't wait to see her all done up. coolsmiley
83GS550
93XR650L TARD!
97WR250
99ValkyrieI/S Tri-tone
01YZ125(x2)
05DRZ-125
Spirited-6
Nicholasville, Ky.
« Reply #8 on: February 15, 2011, 09:00:16 AM »
IT WILL NEVER FLY !  Evil
Good luck, you are a BRAVE MAN !
If I had to go thru all that, I would buy another Bike. Embarrassed
Spirited-6
Red Diamond
Beaumont, Texas
« Reply #9 on: February 15, 2011, 10:36:40 AM »
to take off!
All that, just to change oil, geeze.
5_19
Dublin, Texas
« Reply #10 on: February 15, 2011, 10:46:37 AM »
to take off!
Looks like a good day worth of work! You go!  cooldude TJ
IBA # 45723
2009 BMW R1200 GSA
art
Grants Pass,Or
Grants Pass,Or
« Reply #11 on: February 15, 2011, 11:15:20 AM »
You must be bored there in Ma. with all that snow
Marcel
« Reply #12 on: February 15, 2011, 03:39:26 PM »
WHat kind of Harley is it?
AL
« Reply #13 on: February 15, 2011, 04:08:39 PM »
Ya think so??   Shocked  Actually it needed being done.  She hadn't got much TLC for awhile.  At least I'm past the ripping down and I'm waiting for the parts.  Come on UPS! Wink
Yeah, day, day and 1/2.  Really, I'm taking my time cause just about everything needs cleaning and polishing.  Picking the bugs outta the rad fins was tough. Cheesy
« Reply #14 on: February 15, 2011, 04:10:08 PM »
The kind you don't see every day.  A FAST ONE!
wizard -vrccds#125
Hitchcock Tx.
« Reply #15 on: February 15, 2011, 05:37:03 PM »
been there !                       done that               Its not as hard as I thought it would be. Just one piece at a time !
Red Diamond
Beaumont, Texas
« Reply #16 on: February 15, 2011, 06:39:00 PM »
Hey Wizard, can I get a carb sync and pilot adjustment?
wizard -vrccds#125
Hitchcock Tx.
« Reply #17 on: February 15, 2011, 08:10:01 PM »
Not a problem, as soon as I am done with my project bike. And that should be soon ! uglystupid2
czuch
vail az
« Reply #18 on: February 23, 2011, 01:04:48 PM »
Booze and wrenches and coffie dont mix.
tivoklr
« Reply #19 on: February 24, 2011, 07:45:49 PM »
You start with the coffee then switch to booze say around lunchtime. It's perfect mechanicstyle uglystupid2
