January 28, 2026, 11:22:36 AM
Re: New Brake & Clutch Levers on the way
Topic: Re: New Brake & Clutch Levers on the way (Read 2940 times)
rmrc51
Palmyra, Virginia
April 08, 2009, 03:38:21 PM »
Just ordered wider brake & clutch handles.
I've never replaced these. Is there any special procedure?
Thanks in advance.
VRCC # 30041
PharmBoy
Lawton, Ok
April 08, 2009, 04:15:59 PM »
Which ones did you order? The Goldwing adjustable needs a tab removed as previously posted in another thread. Personally, I bought the ShowChrome levers last year and the clutch slipped until I ground off enough of the stop protrusion on the lever until it matched the OEM clutch lever specs. I have been perfectly satisfied with them since. I like the looks of them and my hands are large enough that I don't mind the reach. Oh yes, just make sure that you don't let the clutch or brake plunger come out. That causes a leak and that dot 4 fluid can be very hard on the paint...JTL
Last Edit: April 08, 2009, 04:31:53 PM by PharmBoy
4th Infantry Tet Vet
99 Interstate
97 Bumble Bee
97 Red & White
rmrc51
Palmyra, Virginia
April 08, 2009, 06:55:39 PM »
Yeah,, I bought the Gold Wing adjustable ones. I know about grinding off that tab, but what I don't know is exactly how to change them.
You mentioned to watch out for a plunger? Are there any sites or links that have pictures on how to change these?
VRCC # 30041
redflash
Southern New Hampshire
April 09, 2009, 08:42:42 PM »
1 nut, 1 pivot bolt to remove for each lever, easy. The plunger will stay put if you don't futz around with it. Put a little synthetic marine grease on the shank of the bolt prior to reinstalling. You'll love the wide levers, I have the Kuryakyn ones, I did. Everything on the Valk should be Texas sized ;-)
rmrc51
Palmyra, Virginia
April 10, 2009, 05:16:34 PM »
Thanks fro the info!
VRCC # 30041
