February 01, 2026, 09:08:24 PM *
Author Topic: Another petcock issue?  (Read 1643 times)
Str8shooter
Loganville, Ga.
« on: February 14, 2011, 04:32:49 PM »
Noticed fuel leaking from the petcock housing. The bike runs fine and does not exhibit the symptoms you here about so often with a failing petcock and diaphragm. I can't see in there well enough to tell if the fuel is leaking from somewhere else and running down the petcock housing so i guess i'll be removing the tank Wednesday. Figures, perfect riding weather this week. Anyone else have this problem?
« Reply #1 on: February 14, 2011, 05:22:18 PM »
This one leaked... gas drizzled out of the weep hole on the petcock...
The previous owner "fixed" it like this:
Having effectively clogged up the weep hole, gas filled the petcock body and
ran down the vacuum hose to fill up cylinder #6. The bike spewed raw gas from
the exhaust when started, I'm glad we fixed it before my buddy Gary ended up with
hydrolock...
valkyriemc
NE Florida
« Reply #2 on: February 15, 2011, 06:04:20 PM »
Happened to my 2002 I/S in '04. Get rid of it. G/L
Veteran USN '70-'76
« Reply #3 on: February 15, 2011, 06:36:40 PM »
tighten the petcock nut to tank connection. it might only need a 1/8 to 1/4 turn.
