February 01, 2026, 09:07:47 PM
Lower custom cover.
Topic: Lower custom cover. (Read 1901 times)
shortleg
maryland
Lower custom cover.
February 18, 2011, 02:28:00 PM »
At the last Inzane I was lucky enough to win
a piece that goes behind the front fender and mounts
to the crash bar in front of the oil filter,it says Valkyrie.
My question is do I have to remove it to change my
oil filter.
Shortleg[Dave]
SCain
Rio Rancho, NM
Re: Lower custom cover.
February 18, 2011, 02:37:54 PM »
No, it sits above the filter, or at least mine does.
Steve
Big Mike
I can not remember my last bad day
Taylor MI
February 18, 2011, 03:07:00 PM »
There are a couple of people that make them. Depending on which one you have, it will make the difference. If the oil filter is exposed then you should not have to remove the cover, when looking at the front of the bike. If the oil filter is covered then you may need to remove it to change the filter.
Big Mike
VRCC 23871
VRCCDS 0200
With GOD and a good attitude, there is no circumstance that I can not overcome.
shortleg
maryland
February 18, 2011, 03:48:43 PM »
Mine is in front of filter,guess I will get the
Drimmel tool out and cut that part off.
You can,t belive what a pain in the Ass
it is to take out those two bolts out and get them
back in.
Shortleg[Dave]
bassman
February 18, 2011, 05:29:57 PM »
Really???
Murdoc
Englewood, Ohio
I do recall that being a slight problem for ya last summer.....
February 18, 2011, 09:08:11 PM »
Have you tried just loosening it and not taking the bolts all the way out? It might flip forward enough to get the filter off without removing the cover...
Redline +
Northwest Washington
Reply #6 on:
February 18, 2011, 09:52:48 PM »
Quote from: shortleg on February 18, 2011, 03:48:43 PM
back in.
Shortleg[Dave]
If it's like mine, filter changes are not a problem.
Redline
shortleg
maryland
Redline do you
Reply #7 on:
February 19, 2011, 04:28:09 AM »
just use a strap wrench to get the
filter off? And then what about install.
Shortleg[Dave]
Redline +
Re: Redline do you
Reply #8 on:
February 19, 2011, 09:13:21 AM »
Quote from: shortleg on February 19, 2011, 04:28:09 AM
Shortleg[Dave]
As a machinist, I always use the correct tool for the job. The correct tool is one that is within reach, that will do the job and do no damage. Last oil change that was a pipe wrench.
I install by hand.
Redline
Reply #9 on:
February 19, 2011, 09:23:32 AM »
Quote from: Redline :) on February 18, 2011, 09:52:48 PM
back in.
Shortleg[Dave]
If it's like mine, filter changes are not a problem. :cooldude
Redline 8)That is a serious nice piece of bling. I LIKE IT!!
