February 01, 2026, 09:08:26 PM *
Author Topic: HEADLIGHT BLUBS FOR 99 INTERSTATE  (Read 2122 times)
Bad On 3
RIDIN THE BEAST ! !
CHICAGO IL. 60638
« on: February 18, 2011, 06:18:17 PM »
HI LOOKING TO CHANGE MY HEADLIGHT BULBS IN MY 99 VALK. INTERSTATE --THINKIN OF THE BRIGHT WHITE ONES  DOES ANYONE KNOW THE BULB # AND THE BEST PLACE TO FIND THESE  HAVIN A HARD TIME FINDING THE RIGHT ONES ---THANKS
Ridin Down The Road Of Life With My Friends !! What a Ride !!
Thunderbolt
Worthington Springs FL.
« Reply #1 on: February 18, 2011, 06:22:07 PM »
you will need to bend back or break off the bottom tabs.
fordmano
San Jose, CA.
« Reply #2 on: February 18, 2011, 07:02:34 PM »
Sylvania Silver star ultras are probably bestbang for the buck, but the PIAA Intense white is brighter and some say last a bit longer but they are kinda pricey.
I will post up the links and descriptions when I got off of this phone and get into the office tonight (about 1.5 hours from now) check back after that if you still need information.
You can go up to the 100watt bulbs but for safety you might want to consider replacing your sockets with the high temp automotive replacement sockets like many others have found out
83GS550
93XR650L TARD!
97WR250
99ValkyrieI/S Tri-tone
01YZ125(x2)
05DRZ-125
Sambeaux
'99 Std
Daphne, Alabama
« Reply #3 on: February 18, 2011, 07:32:12 PM »
I have been running the NAPA 100 watt bulbs for a couple of years without problems.  Some have had issues with the heat.
I have been looking at the 6000k HID Xeon conversion kits - lots of suppliers on the net.  These are generally advertised as brighter, drawing less power (35 to 55 watts) and having a greater range.  Haven't found what I consider a good source for "real world" applications but can see the potenial.  Have seen several past thread where folks have discussed ths equipment but no good first hand accounts or experiences.
Best
Sambeaux
fordmano
San Jose, CA.
« Reply #4 on: February 18, 2011, 09:34:10 PM »
I found the information on the headlights bulbs as a reference for you. Directly from PIAA website.
Twin Pack 10904
Single Pack 10934
Bulb Type H4
Wattage 60/55w = 135/125w, 4100K
Technology Intense White
Here is an older picture with them lit up, you can get a slight idea of how they look. The headlights in this are the PIAA 60/55 watt Intense white I think they are on the low beams here.  And the POD lights are also PIAA 55watt intense white bulbs.
EDIT: here is the info on the POD foglights from PIAA website.
Twin Pack 10903
Single Pack 10933
Bulb Type H3
Wattage 55w = 100w, 4100K
83GS550
93XR650L TARD!
97WR250
01YZ125(x2)
05DRZ-125
fordmano
San Jose, CA.
« Reply #5 on: February 18, 2011, 09:53:10 PM »
Not associated or offer this place with any personal experience just was the first one I found when I googled "Sylvania H4 SilverStar Ultra"...
http://www.autobarn.net/syl9003su.html?site=google_base
$39.95 for a pair that seems like a good price, sorry did not check on tax or shipping.
I also searched for the PIAA H4's at the same online store and WOW! $48.95 this is a good price for a pair of these bulbs I think I paid over $65.xx for the ones I bought.
http://www.autobarn.net/pia10904.html
« Last Edit: February 18, 2011, 09:59:39 PM by fordmano » Logged
83GS550
93XR650L TARD!
97WR250
01YZ125(x2)
05DRZ-125
Bad On 3
RIDIN THE BEAST ! !
CHICAGO IL. 60638
« Reply #6 on: February 18, 2011, 10:13:01 PM »
THANKS YOU GUYS ARE THE BEST !!!!!  IF I GO WITH THE H4 DO I NEED TO TAKE OFF THE BOTTOM TABS  I ALSO HEARD I NEED TO BUY SHIMS OR A SPACER TO MAKE THESE WORK   I WANT THE WHITE LIGHTS BUT I DONT WANT TO MESS ANYTHING UP ---THANKS AGAIN
fordmano
San Jose, CA.
« Reply #7 on: February 19, 2011, 12:32:09 AM »
Lots of folks say the shims are NOT needed, I do not know for sure if that is true..
When I upgraded a few years back I read lots more saying you needed them than folks saying you did not need them so I bought a set of shims and installed them when I installed the lights and they worked perfectly so I never tried going without the shims in place.
Yes you have to clip off the 2 lower alignment tabs for them to fit into the headlight sockets.
Good luck with whatever route you choose. cooldude
83GS550
93XR650L TARD!
97WR250
01YZ125(x2)
05DRZ-125
« Reply #8 on: February 19, 2011, 06:33:10 AM »
Many have been using 80-100 H4 (off-road) bulbs in the interstate (not the std/tourer bucket) with no heat issue in the fairing or wiring, instead of the usual 55-60 H4 auto bulbs.  Properly aimed, the 80 W dims way outshine them, and still do not get flashed by oncoming cages at night.
You cut the tabs, and do not need the shims.
http://www.valkyrieriders.com/shoptalk/interstateheadlight.htm
http://www.slickcar.com/productdetails.asp?ProductID=3269
http://www.customstreetdesigns.com/3269-H4%20APC.htm
http://www.amazon.com/Hella-HLA-H83140171-Halogen-Bulb-Road/dp/B000COBLKW/ref=pd_sim_auto_1
Bad On 3
RIDIN THE BEAST ! !
CHICAGO IL. 60638
« Reply #9 on: February 19, 2011, 02:50:52 PM »
THANKS AGAIN --THE WEB SITE YOU SENT ME IS GREAT --SHOWS WHAT TO DO ---I ORDERED THE SHIMS ---THANKS AGAIN YOU GUYS ON THIS WEB SITE ARE GREAT --I DONT DO ANYTHING ON MY INTERSTATE WITHOUT CHECKING WITH YOU ----THANKS AND HAPPY AND SAFE RIDIN !! Cool
