February 01, 2026, 08:51:16 PM *
Author Topic: air in brake lines?  (Read 2104 times)
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« on: February 18, 2011, 06:40:09 PM »
I may have air in my rear brake lines.  Other than bleeding them is there a way to get it out?  I thought I remember something about holding the brake pedal down overnight?
Dropbox is a neat app I found that I use to store files and pictures of my Valk.
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #1 on: February 18, 2011, 07:34:27 PM »
zeus661.....bleed the lines.  if it'been more than 2 years since you changed the fluid, go ahead and change it now too. cooldude
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« Reply #2 on: February 18, 2011, 08:03:13 PM »
I did change it but think it may have gotten some air in it.  I checked the pads and they were almost new looking but the brake pedal feels like before the fluid change, kind of soft and it seems to go down more than it should.
olddog1946
Moses Lake, Wa
« Reply #3 on: February 18, 2011, 08:31:35 PM »
I use a mighty vac (hand vac) to draw fluid through the system. It seems to work pretty well..
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #4 on: February 18, 2011, 08:49:03 PM »
zeus661.....sometimes you might have to bleed the system several times to get all the air out...i too use a mighty vac to bleed, and or change the fluid.  go back and bleed it again... you might be suprised that this extra couple of bleedings will take care of your problem cooldude
Bobbo
Saint Charles, MO
« Reply #5 on: February 18, 2011, 08:55:52 PM »
Sometimes an air bubble can get trapped in the caliper, and slow bleeding may not push it out.  Try connecting a snug fitting hose to the bleeder, with the other end in a jar of brake fluid.  Open the bleeder enough to allow fluid to flow, and give the handle or pedal a quick “jab”.  Hold it down, and close the bleeder.  This will usually dislodge a stubborn bubble.  Also if the reservoir went dry during bleeding, you may have to bench bleed the master cylinder.
Bone
« Reply #6 on: February 19, 2011, 03:44:32 AM »
I've seen the front brake lever tied down many times. Never noticed a brake pedal but why not give it a try. I've used the Mity Vac for many years works good.
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« Reply #7 on: February 19, 2011, 06:05:33 AM »
Thanks for the tips. Will give them a try.
« Reply #8 on: February 19, 2011, 06:08:39 PM »
If you care enough to change the brake fluid, then you should have a lot left after doing your system, and it should be thrown away by the time you do your next replacement, as you need to start from a freshly opened container.
If you're like me, and I haven't replaced brake fluid for any vehicle I owned in over 30 years, then doing a proper bleed is still the way to go. You where hoping that just holding the pressure in the line would allow the air to come out slowing may work, but this would take multiple times, over multiple days, wouldn't it just be easier to do a proper bleed in conjunction with a vac pump?
tybme
1999 Valkyrie I/S
Topeka KS
« Reply #9 on: February 22, 2011, 09:40:40 AM »
I have great luck with speed bleeders.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways. totally worn out, shouting, "Holy ****... What a Ride!"
RainMaker
Arlington, TX
« Reply #10 on: February 22, 2011, 10:48:03 AM »
If you change out the fluid in the front and rear brakes plus the clutch, you will use almost an entire bottle of brake fluid. That way, you won't have to throw much away.
2005 BMW R1200 GS
2000 Valkyrie Interstate
1981 GL1100I GoldWing
1972 CB500K1
JC
The Beast
Franklin, TN
« Reply #11 on: February 22, 2011, 01:18:49 PM »
+1   cooldude
Got them on all brakes and clutch. Works great!
vanagon40
Greenwood, IN
« Reply #12 on: February 22, 2011, 03:20:05 PM »
If you care enough to change the brake fluid, then you should have a lot left after doing your system, and it should be thrown away by the time you do your next replacement, as you need to start from a freshly opened container. . . .
Uhm. . . .  I figured the two year old stuff in the capped bottle in my garage was better than the two year old fluid in my bike.  It was certainly a lot cleaner.
In case it was not clear, I did NOT start from a freshly opened container on my last fluid change.
To each his own.
Hey Zeus661, how many miles on the bike and how many (if you know) on the pads?  If you pump the pedal, does it get firmer?
« Last Edit: February 22, 2011, 03:23:53 PM by vanagon40 » Logged
