September 14, 2025, 12:16:00 PM *
Author Topic: Wicked Awesome  (Read 1141 times)
Stude
« on: February 20, 2011, 02:27:47 PM »
Too cool of an idea for a motor... I can see this in a motorcycle frame (cut and paste the link)
http://www.engineeringtv.com/video/Opposed-Piston-Opposed-Cylinder
« Reply #1 on: February 20, 2011, 03:35:40 PM »
Stude, over 40 yrs. ago I designed an engine very similar. The main difference was my design had a single "double headed" piston(piston at ea. end, all one piece) with a combustion chamber at each end with no valves in the chamber. The power take-off was in the center of it fashioned somewhat like a Scotsman Yoke, not a crankshaft as we know it. It also didn't have a cam or intake/exhaust valves, just exhaust ports like the vidoe engine has, however the intake was via injection. The way I designed it, every 360 deg. gave two power strokes from what was essentially a two cylinder engine. It had fewer moving parts than the one in the video.
My problem at the time, I was out of work and had no money. Our patent system is such that it discourages invention and development because of the cost. I couldn't find any investors...honest ones at least, and those that would invest wanted total control. No dice on that, I would have been booted in six months. The result was, I trashed the whole thing, literally cut it up with a metal bandsaw.
At present, I'm messing with an idea for a new design of electric motor. If it works, it should have extremely low power requirements with high output of torque. I have no idea if it will work, but it keeps my mind busy anyway. So, if one day the power grid in the SE part of the U.S. goes down, you'll know I'm running some experiments.  Grin
Stude
« Reply #2 on: February 20, 2011, 04:10:37 PM »
Too bad you trashed your old idea... sounds like you were on to something. But what you're working
on now might make up for it.
 Do you remember the HO slot cars from the 60's that had two magnets 1 on each side of the armature...
up scale that idea to a generator... to power a house.
Then hire me to count the money you make off of it Smiley
Thunderbolt
Worthington Springs FL.
« Reply #3 on: February 20, 2011, 06:43:28 PM »
and if they have acutally used it.
Bobbo
Saint Charles, MO
« Reply #4 on: February 20, 2011, 07:10:35 PM »
Would your motor design include supercooled ceramics?  I have designed a few experimental motors that use temperature phase change (similar to a Curie point) to enhance the efficiency of the motor.  The ultimate goal was to not use electricity at all to run the motor, just cycle around the phase change point.
blotar
VRCC #32549 VRCCDS#0237
Crosby, Texas
« Reply #5 on: February 20, 2011, 07:20:24 PM »
Bobbo, MEG (motionless electric generator)
http://vrcc.photostash.com/vrcc_32549/VisitedStatesMap3.jpg
1998 Valkyrie CT
1995 V-Max [img width=347 height=175]
1995 Yamaha Virago 1100
1994 Suzuki GSX 1100 G
1995 Honda Shadow 1100
1994 Honda Magna 750
196? BSA Hardtail
1973 K3 Honda 750
1964 Allstate 250
« Reply #6 on: February 20, 2011, 07:32:16 PM »
Well, they're still kicking at least...
http://www.autoblog.com/2010/07/13/ecomotors-gets-23-5m-boost-from-bill-gates-vinod-khosla/
Bobbo
Saint Charles, MO
« Reply #7 on: February 20, 2011, 07:39:46 PM »
A MEG modifies a static magnetic field from a permanent magnet to generate an alternating flux field.  My work used the magnetic flux generated from supercooled ceramic materials, which can be modified with temperature.
« Reply #8 on: February 20, 2011, 08:15:15 PM »
No, nothing exotic like that. The idea was to keep it simple and totally self-contained so the applications would be wide ranging.
Bobbo
Saint Charles, MO
« Reply #9 on: February 20, 2011, 08:29:55 PM »
Let us know when you get it working!
