February 01, 2026, 10:28:54 PM *
Author Topic: Got Breakaway Cruise Control and Kurys?  (Read 1942 times)
BIG--T
The Twilight Zone
« on: February 21, 2011, 04:30:13 PM »
Well my Breakaway CC finally just came in from DLP. Before the UPS guy showed up, I found from the Cruiser Customizing website that I will need a Cam riser kit to work with my Kury chrome levers. DLP should have suggested the same if there's any truth to it
I called DL and the guy said about 70% of the people don't need the cam riser kit, which didn't make sense unless Kury is just  trying to line their pockets! I told him I hope I'm in the 70%.
Has anyone had any experience with this combo?
Thanks in advance for any help.  Smiley
BIG--T
The Twilight Zone
« Reply #1 on: February 22, 2011, 10:05:09 AM »
Surely someone out there has both BAC and Kury levers. Help!! uglystupid2
« Reply #2 on: February 22, 2011, 10:15:28 AM »
When we were looking at your levers, I thought you had this kind, but I don't know...
BIG--T
The Twilight Zone
« Reply #3 on: February 22, 2011, 10:33:01 AM »
Mike the guy I bought it from had the factory levers packed in the Kury package Mod# 7429.  Just by looking, the Kurys don't look any wider. Acordding to CC that model needs the cam kit. Sad
Tony
rrmdeuce
Los Angles
« Reply #4 on: February 22, 2011, 11:06:03 AM »
Xguy.
I have Kury levers and a brake away and didn't need anything extra. I did need to fuss with the alignment to get it to work off the lever.
BIG--T
The Twilight Zone
« Reply #5 on: February 22, 2011, 11:29:32 AM »
Xguy.
Thanks rrmdeuce that's very encouraging! Do you have the Kury 7429 chrome levers? Yeah the instructions look complicated and have heard from several it was a beach to align and get it right! The old boy at DL might have been right after all and I'll fall into that 70%.
Again thanks again and I'll get started tonight. cooldude
NITRO
Eau Claire, WI
« Reply #6 on: February 22, 2011, 07:25:29 PM »
I had both on my Standard and the brake-away feature (lock releases when you hit the front brake) no longer worked. I adjusted things as far as I could and got it to work again, but it wasn't nearly as smooth of a release as before. I haven't bothered to install the lock my Interstate yet and now have an Audiovox CC to install, so I'll probably just sell it. They look fantastic and work great when set up correctly, you'll like it.
When in doubt, ride.
BIG--T
The Twilight Zone
« Reply #7 on: February 22, 2011, 07:47:06 PM »
I had both on my Standard and the brake-away featurerk aga . I haven't bothered to install the lock my Interstate yet and now have an Audiovox CC to install, so I'll probably just sell it. They look fantastic and work great when set up correctly, you'll like it.
(lock releases when you hit the front brake) no longer worked. I adjusted things as far as I could and got it to woin, but it wasn't nearly as smooth of a release as before
When you say  it no longer worked, was that because you put on Kury levers?
Flat6Valk
Blacklick, Ohio
« Reply #8 on: February 27, 2011, 07:26:39 PM »
I have a Brakeaway and wide lever Kurys.  I was able to get the brakeaway to work without the riser but it was a little sloppy.  I called Brakeaway and they sent the parts needed to make it right free of charge.  Free is best and using the riser is best as well.
« Reply #9 on: February 27, 2011, 07:36:34 PM »
I didn't need anything extra.  There was enough adjustment in the system to compensate for the wider levers, in my case.  Or I modified it a little, I don't recall.  I do that sort of thing without thinking about it much, with all the tools I have in the metal shop - I tend to expedite an install myself with what I have on hand, rather than get some outside support.  Maybe I'm not being much help here...
BIG--T
The Twilight Zone
« Reply #10 on: February 28, 2011, 07:17:30 AM »
Flat6 you were lucky because I emailed them and they said I needed it and gave me the P/N. Yes you can't beat free! I'm going to put them on today and make them work! I haven't even looked a my BRA and my levers good yet. I think I will take the Kury lever off, lay my OEM on top of it. mark and cut it the same as the OEM where in engages the cruise.  cooldude
BIG--T
The Twilight Zone
« Reply #11 on: February 28, 2011, 07:24:58 AM »
Thanks Mark, Yes you are a lot of help and thanks for the encouragment!  Hopefully  I won't have to do nothing, but I'll ger her on there regardless!
Thanks cooldude
