March 22, 2026, 06:42:39 AM *
Author Topic: electricians???????????...  (Read 2447 times)
bg
Cumming, Ga
« on: February 22, 2011, 01:19:19 PM »
this is non valk related but we have such knowledgeable folks here I need to give it a shot.
I'm getting a audible "chirp" coming from the area of the smoke detector.
it chirps about every 40 seconds. The kind of chirp that some electronics have built in to let you know the battery is low.
I"ve taken down all detectors (they are only 2 months old), unwired the connections from the romex to the  pigtail  and still hear the chirp.
just a few minutes ago I turned off all breakers....still chirped.........then i cut the main off......still chirped.
I'm at my wits end and have no idea what to check next.
any ideas??????????
flcjr
Manhattan,Montana
« Reply #1 on: February 22, 2011, 01:21:39 PM »
put new batteries in them!!
« Reply #2 on: February 22, 2011, 01:23:04 PM »
I probably don't understand what you're saying, but...
(all?) hardwired detectors have battery backups...
Mine are all battery only...
« Reply #3 on: February 22, 2011, 01:28:10 PM »
Battery.
« Reply #4 on: February 22, 2011, 01:30:16 PM »
Are you able to physically remove the smoke detector(s)? Are ALL of them chirping, or just one or a few?
(Not an electrician, but tracked down enough "OH MY GAWD SHUT UP I CAN'T SLEEP!!!!!" issues with smoke (And Carbon Monoxide!) detectors to feel like one sometimes...)
« Reply #5 on: February 22, 2011, 01:32:53 PM »
New batteries should cure the chirp for ya.........
bg
Cumming, Ga
« Reply #6 on: February 22, 2011, 01:44:49 PM »
all batteries are removed, all detectors are disconnected and laying in my work room.
cut the power to the entire house and still have the chirp.
the chirp is coming from the second floor.
i've even gone up into the attic to see if i can find anything up there.........no luck.
i'm at a complete loss.
the chirp did quit for about 4 days but started up again this morning.
i'd  pull my hair out if i had any.
« Reply #7 on: February 22, 2011, 01:46:34 PM »
Carbon monoxide detector near any gas appliances? (Heater, water heater, etc) possibly?
You made any geeks mad lately?
http://www.thinkgeek.com/gadgets/electronic/8c52/
(Semi serious on that suggestion...  coolsmiley )
« Reply #8 on: February 22, 2011, 02:06:43 PM »
Ooops, I understood ya to say you had pulled the chirper down.
Now it sounds like you haven't located it yet.
Keep lookin as it could be a carbon dioxide one going off.
Mine does that every so often, but all I have to do it is unplug it, let it rest about 5 minutes and it is good to go for another 2 years.
alph
Eau Claire, WI.
« Reply #9 on: February 22, 2011, 02:57:10 PM »
they chirp for two reasons, one, the battery is low, two there isn't any AC power.  when you tell me that you took it down, now, it's saying "HEY!  WERE'S THE AC!!".  it's a trouble signal, my father in law had the same problem turned out to be a bad wire terminal on the back.  also, it might be dirty.  some (i do mean some) smoke detectors are able to be washed under running water, of course, they shouldn't be plugged in and the battery should be taken out, make sure that it is washable.  hard to diagnose without being there.....
al.
« Reply #10 on: February 22, 2011, 03:26:31 PM »
Alph, I might be misunderstanding, but I don't believe he's narrowed it down to a specific smoke detector, but the sound sounds like one...
Or am I not understanding the situation correctly?
Big IV
Iron Station, NC 28080
« Reply #11 on: February 22, 2011, 04:39:07 PM »
Any crickets in the house? Bird in the chimney?
"Ride Free Citizen!"
VRCCDS0176
chrise2469
Winnipeg Manitoba Canada
« Reply #12 on: February 22, 2011, 05:44:37 PM »
Is there a Logitech remote on that floor? I had a remote that had a bad nubmerpad that was replaced.  I left the bad one on the AV rack.
Took me weeks to finally track down the intermittent beep of the low battery.  I checked every smoke detector and every other remote but forgot about the broken guy until it beeped when I was loading a Blu-ray.
Might be some other battery powered device-remote, key fob, or clock radio.
Big Rig
Woolwich NJ
« Reply #13 on: February 22, 2011, 05:50:14 PM »
bg,
Just went thru this about a month ago...you have one that is bad...so if you have re-attached them. listen to the one that is cherping and replace jt. You can not get these at the big box stores. The sensors go bad over time and need replacing, the cherp is it letting you know.
Best of luck.
tank_post142
south florida
« Reply #14 on: February 22, 2011, 06:21:04 PM »
quote: all batteries are removed, all detectors are disconnected and laying in my work room.
I got a rock Sad
VRCCDS0246
tank_post142
south florida
« Reply #15 on: February 22, 2011, 06:23:10 PM »
1 case of beer, 6 friends, spread them out upstairs, kill the power and wait
I got a rock Sad
VRCCDS0246
Jess Tolbirt
White Bluff, Tn.
« Reply #16 on: February 22, 2011, 07:16:54 PM »
somebody hid an extra smoke detector inside the wall when the house was built about 2 years ago or so and now the battery is low enough to cause it to start its chirping...
Valkyrie member # 23084
alph
Eau Claire, WI.
« Reply #17 on: February 22, 2011, 10:57:27 PM »
i wouldn't laugh.  i've seen crap like that before.....  amazing what somepeople will do....
so, you took ALL of them down, killed power, and you still hear a chirp?
is there posibly a wireless switch somewere?  some kids room were they wanted a switched outlet, or something like that, but didn't want to run a wire?  wish i was at your house, this has me scratching my head, and there's not much hair there!!
bg
Cumming, Ga
« Reply #18 on: February 23, 2011, 01:48:06 AM »
wireless device???? i do have photo sensor lights that come on at dusk and go off at dawn on my garage.
i've been in this house for 14 years and this is the first time i've had this   problem.
only new electrical device that uses batteries i've bought lately is a laptop. however the problem started before i purchased it.
again, all detectors are down, batteries removed, bare wires hanging (taped and capped) where the detectors used to be and still chirping. even killed all power to the house and still had the stupid beep.
it is so typical of a low battery chirp, but being in this house as long as i have it unthinkable of a battery just now running low.
14 years is a long long time for a battery of any kind.
G-Man
White Plains, NY
« Reply #19 on: February 23, 2011, 07:17:50 AM »
I'm betting on a little birdie caught somewhere.
tank_post142
south florida
« Reply #20 on: February 23, 2011, 07:23:06 AM »
its the louvers on the whole house fan!!
I got a rock Sad
VRCCDS0246
fast black
centerton, arkansas
« Reply #21 on: February 23, 2011, 07:25:46 AM »
I believe it is a carbon monoxide detector  with battery backup with low battery.
Hef
Opdyke, IL 62872
« Reply #22 on: February 23, 2011, 07:37:40 AM »
Sounds like a job for "GHOST BUSTERS" Sorry, I couldn't resist. I know this has to be frustrating. Hope you find the cause real soon.
Hotrodwing
Clarks Summit PA
« Reply #23 on: February 23, 2011, 09:33:39 AM »
Do you have an alarm system in your house it will also chirp when ac power is removed.
Titan
BikeLess
Lexington, SC
« Reply #24 on: February 23, 2011, 10:03:13 AM »
How about a battery backup system for your computer(s)?
bg
Cumming, Ga
« Reply #25 on: February 23, 2011, 12:27:15 PM »
to all who replied.......thank you.
got the sucker taken care of.
turns out it was the old smoke detector my wife had stuffed on the bottom shelf, way in the back of the linen closet just to "get it out of the way".
the sound was coming from the bottom shelf, up the closet walls and out the electrical outlet where i was installing the new detector.
what a relief.
thanks again.
Pale Rider
« Reply #26 on: February 23, 2011, 01:19:19 PM »
Big Rig DH is correct.  These units have a shelf life, mine were about 10 years, until the sensors took a crap.  New batteries will not remedy the problem, but give it a try.  All styles are easily found at the big box stores.  These units do have some stored energy.......if they continue to chirp after removing both the ac and dc source, depress the test button and it will chirp and then peter out.
