March 22, 2026, 06:42:36 AM *
Author Topic: Temp light acting odd  (Read 1188 times)
boxo
« on: February 23, 2011, 09:52:46 AM »
Hello Valkyrie people
My 98 has ben showing me the temp light at odd times off and on and, not on at all for a day or two.
Has any one had this kind of an isue before?  Thank you
Mikey
Winona, MN
« Reply #1 on: February 23, 2011, 09:54:21 AM »
My temp light comes on when I hit the rev limiter... That's the only time I've had mine come on.
Remember folks, street lights timed for 35 mph are also timed for 70 mph
VRCC# 30782
« Reply #2 on: February 23, 2011, 09:56:01 AM »
Look for a fraid <(sp) wire or a bad connection.
If neither of those, then I'd test the switch out and see if it is trying to head South on ya.
Six Guns
Fort Worth, Texas
« Reply #3 on: February 23, 2011, 11:56:32 AM »
I had that happen as well. It's a bad module under the left side cover behind the coolant bottle. Give me a few minutes to look it up in the Tech Archives and I will post back here with the part number that you need.      cooldude
Six Guns
Fort Worth, Texas
« Reply #4 on: February 23, 2011, 12:35:34 PM »
O.K. I found it. Replacing this module fixed my problem. It's behind the left side cover behind the coolant bottle. Check the Tech Archives and search for a post by RP#62 for Coolant problem.
Its listed as 38710-MZ0-003
INDICATOR UNIT, TEMPERATURE (Honda Code 5051974)
#16 in the diagram
Spirited-6
Nicholasville, Ky.
« Reply #5 on: February 23, 2011, 12:54:53 PM »
Damn Mikey, you are @ red line and you`re looking down at the TEMP. light ?  WHEW !  crazy2  Evil
Spirited-6
