March 22, 2026, 08:22:13 AM *
Author Topic: Harbor Freight Motorcycle Wheel Chock  (Read 6720 times)
X Ring
VRCC #27389, VRCCDS #204
« on: February 24, 2011, 04:35:45 AM »
I was able to pick up a Harbor Freight Wheel Chock on sale from their website for $39.99 instead of $49.99 then used a 20% coupon for another 8 bucks off.  With tax and shipping it will cost me $45.   If I went to their store in Mobile, AL it would have cost me a few more dollars plus the aggravation of dealing with Mobile's traffic and it's not like I need it right now.
Here's the link to the chock:  http://www.harborfreight.com/motorcycle-wheel-chock-96349.html
The Coupon Code is TOOL20
Marty
« Last Edit: February 24, 2011, 05:16:56 AM by X Ring » Logged
larryd
# 31416.........2001 standard
Rochester, N.Y.
« Reply #1 on: February 24, 2011, 04:56:24 AM »
That is the same one I use. Fits the front tire nice and snug. Very pleased with it. Good investment.
2001 valk standard
Mr.BubblesVRCCDS0008
« Reply #2 on: February 24, 2011, 05:15:23 AM »
I've got that one mounted in my garage. I use the center hole on the  pivot point makes it fit good and tight.  cooldude
MNBill
Southern Minnesota
« Reply #3 on: February 24, 2011, 05:42:27 AM »
Thanks for the information, order placed.
MNBill
SE Minnesota
« Reply #4 on: February 24, 2011, 06:51:03 AM »
I have that one as well, but I was unhappy with how narrow the leading edge is....I cut the front off and welded in some rebar that was formed to more closely match the profile of the front tire......its made for a chopper front tire IMO too narrow for a normal Valk tire
« Reply #5 on: February 24, 2011, 07:11:26 AM »
I stretched mine out to keep it from pinching my front tire... I use it often when doing maintenance...
Spirited-6
Nicholasville, Ky.
« Reply #6 on: February 24, 2011, 09:25:28 AM »
DITTO. but still hard to pull OFF with my short legs. Wife pulls real good .
BTW, I paid $29.99 at HF.  Wink
Spirited-6
PharmBoy
Lawton, Ok
« Reply #7 on: February 24, 2011, 09:58:15 AM »
Mount it on a 2' X 8' X 5/8" plywood board and it works just fine the way that it comes.  Just mount it with countersunk carriage bolts so it does not slide on the floor.  Those front tires are tough and will take a lot more than the slight pinch inflicted by this chock. Most any bump in the road is harder on that tire than a gentle pinch. I've had one for 3 years and love it.  Just park it and walk away...JTL
4th Infantry Tet Vet
99 Interstate
97 Bumble Bee
97 Red & White
« Reply #8 on: February 24, 2011, 10:05:54 AM »
Good to know... I used to imagine using it to park my bike, but once I got it and saw how the tire was crammed in there,
I was afraid it might deform the tire if the bike sat there for, you know, what if you didn't ride for a few weeks ... ?
« Reply #9 on: February 24, 2011, 11:03:53 AM »
Exactly what I did, the sides hit the brake rotors until I did it.  It was impossible to use on a valk until I did. It is bolted in the front of my trailer, in case the missus wants to go with me when I got a ways to go. Put 18k on the bike last year excluding the towed miles, just in case anyone wondered.   Wink   Grin   Hoser
« Last Edit: February 24, 2011, 01:50:14 PM by Hoser » Logged
T-Bird
Cleveland, Tennessee
« Reply #10 on: February 24, 2011, 11:42:20 AM »
Does anyone have this one from HF, and how do you like it?
Stanley Steamer
Athens, GA
« Reply #11 on: February 24, 2011, 01:32:02 PM »
I bought one of those and used the .22 shell nail gun to fasten it to the concrete floor of my motorcycle building.....I don't leave the bike in it all the time(it does pinch the front tire pretty tight and I haven't stretched mine out yet)...only when I'm working on it and need it to sit upright....I added a motorcycle tie down strap as added insurance in this pic....it will probably come in handy when we replace the alternator..... cooldude
Stanley "Steamer"
"Ride Hard or Stay Home"
ricoman
Sarasota, FL
« Reply #12 on: February 24, 2011, 02:26:33 PM »
I have that one and mounted it to a 10"X6' piece of plywood. Before I did that it would slide when you rode the bike onto it.
Works great after you get the pivot bolt/pin set for the Valk front wheel Sometimes it can be a minor chore to pull the bike back to roll it off. My bike stays on the chock in the shop when I'm not on it. No tire pinching issues at all.
Wait for a sale-they are often under 50 bucks.
Master Blaster
Deridder, Louisiana
« Reply #13 on: February 24, 2011, 05:28:28 PM »
I have 6 of them, 4 for the tandem axle, and two for the two wheeler.  The piece that wraps the front of the tire is just a light hollow tube, and I had one of mine break while trailering, but overall they have been good.  If  I neglected to check at every stop it would probably have done some damage, but I caught it in time.  I made mine quick detachable  by removing a couple of pins so the trailers can be used for other things.  For the price they are good enough.
TearlessTom
Spanish Fort, AL.
« Reply #14 on: February 24, 2011, 10:00:48 PM »
I agree it needs to be mounted to the floor securly or to a piece of plywood otherwise it slides and is difficult to dismount.
What setting do you have yours in for the Valk?
I also you two of the 1st ones for my trailer when towing the bikes.
