July 26, 2025, 03:43:29 PM *
Author Topic: Pet rooster  (Read 3218 times)
gomato@aol.com
« on: February 25, 2011, 09:45:55 AM »
I have 2000 STD and want to know if can convert the stock pet rooster to a non vacume valve so it is a manual valve. Thanks  ... GT
bigfish_Oh
Allis
West Liberty,Ohio 43357
« Reply #1 on: February 25, 2011, 09:55:11 AM »
search is your friend..... many have went to manual pingle and use it every ride.
it is one of the top ten debates - pro/con issues ?????
2012 HD Road King Classic, Teq sunrise/HD Orange
2009 HD Nightster,orange
1974 CB550F,org
1999 Valkyrie,orange/Black (20K)
2009 GMC 3500 Duramax CC Dually 4wd (new)
1957 WD45 Allis Chalmers Grandpa bought new
1982 CBX (new)
1980 CBX (6K)
1979 CB750F (new)
1958 Lambretta TV175 (Dad's new)
4
Bone
« Reply #2 on: February 25, 2011, 10:02:24 AM »
Search isn't my friend I just tried it and get zero results.
I have done it on my 98 Tourer and will show you the directions I used if I can find where I have them stashed Sad
Bone
« Reply #3 on: February 25, 2011, 10:20:36 AM »
http://daughertymotorsports.com/howto/tankvalve/tankvalve.html
This was posted after I ordered the cover set to rebuild my petcock. I converted mine and it's still that way. I will put the kit in it someday. Many recommend the Pingle as a replacement I just like the original.
Brad
Reno, Nevada
« Reply #4 on: February 25, 2011, 10:56:15 AM »
I was scared to open this thread.  Petcock is NOT two words.    Smiley
Mr.BubblesVRCCDS0008
« Reply #5 on: February 25, 2011, 11:03:16 AM »
Search under my handle. I did it better than 3yrs ago and still running that way.
Kaiser
Gainesville, FL
« Reply #6 on: February 25, 2011, 11:07:34 AM »
 Grin Me too!
Making it two words and doing an internet search will probably bring back some unintended results.   Evil
Bobbo
Saint Charles, MO
« Reply #7 on: February 25, 2011, 11:22:56 AM »
 Grin Me too!
What??  There's nothing wrong with domesticated chickens!!   Evil
NITRO
Eau Claire, WI
« Reply #8 on: February 25, 2011, 11:30:06 AM »
 Grin Me too!
Me three!
When in doubt, ride.
« Reply #9 on: February 25, 2011, 11:33:45 AM »
 Grin Me too!
 2funny  2funny  2funny
« Reply #10 on: February 25, 2011, 01:07:34 PM »
http://www.valkyrieforum.com/bbs/index.php/topic,18092.msg154186.html#msg154186
gomato@aol.com
« Reply #11 on: February 25, 2011, 03:41:59 PM »
OK, OK, it's one word! But......... I got the results I was after. Thanks...
GT
Mildew
Live, Not Just Exist
Auburn, Ga
« Reply #12 on: February 25, 2011, 05:50:38 PM »
I got mine fixed. I just put a gasket on the inner part and tossed all the inside parts. (5 min job) I wish I would have filled the outer piece with a good silicone just incase the gasket breaks. I'll probably do that tomarrow night if I have time. Over 200 miles and it rides great.
« Last Edit: February 25, 2011, 05:52:14 PM by Mildew » Logged
PhredValk
Edmonton, Alberta, Canada
« Reply #13 on: February 25, 2011, 09:39:28 PM »
So remove the innards and use the stock petcock manually, and this works and is safe? Sorry, I ordered the engine hanger covers the other day, and I doubt they would work or look great with the pingell.
Fred.
VRCCDS0237
Fathertime
Washington County, New York
« Reply #14 on: February 25, 2011, 09:58:36 PM »
There are WAY too many ways to go with this subject line.
tank_post142
south florida
« Reply #15 on: February 25, 2011, 10:27:47 PM »
i can't believe the auto censor allowed the title!!
I got a rock Sad
VRCCDS0246
Mildew
Auburn, Ga
« Reply #16 on: February 26, 2011, 03:33:44 AM »
Fred.
I don't know about safe but it works for me. I've been working 7 days a week with 110 mile round trip ride back and forth so its hard for me to spend a lot of time searching. I seen where this subject has been brought up a lot though. The petcock will be manual this way and is not dummy proof. Every bike I had since I was a kid worked this way. I couldn't believe Honda would alow something made like that. It did last 10 years though.
« Last Edit: February 26, 2011, 03:36:13 AM by Mildew » Logged
3W-lonerider
Shippensburg Pa
« Reply #17 on: February 26, 2011, 04:41:14 AM »
one word of advice mildew Do NOT USE SILICONE any where there is gas present. gas will disolve silicone and it will end up stuck in one of your floats..so you've just created the very problem you were trying to get away from.
Cliff
Manchester, NH
« Reply #18 on: February 26, 2011, 05:13:15 AM »
+1 darn good advice!!!!
VRCC # 29680
gomato@aol.com
« Reply #19 on: February 26, 2011, 08:22:19 AM »
But you still have to plug the vacume tube on the the #6 carb...right??
GT
Bone
« Reply #20 on: February 26, 2011, 08:53:09 AM »
Depends on what you do with the fittings on the petcock
Reattach the vacuum hose so you don't have to think of another way to seal the vacuum nipple on the carburetor.
or    ( I used the method below)
The last step is to plug where the vacuum line used to connect to the rear head.  I like to use a bolt with a sealing washer under the head, but you can also use a vacuum port cap over the stock barb.  Make sure to get a good seal.
« Last Edit: February 26, 2011, 08:58:23 AM by Bone » Logged
Mildew
Auburn, Ga
« Reply #21 on: February 26, 2011, 04:51:56 PM »
Oooops! What happens if you didn't  do the last step 300+ miles ago ???
« Last Edit: February 26, 2011, 04:53:44 PM by Mildew » Logged
Mildew
Auburn, Ga
« Reply #22 on: February 26, 2011, 05:12:33 PM »
Yea, I thought of that but then I thought if the silicone was behind the gasket it shouldn't touch the fuel. Your right though. It too good of a motor to take that kind of chance. I guess the smartest thing to do is buy a pingle. I've never had any luck in the past with jb weld because of the cracking when it gets warm then cold. That's why I thought silicone would be a better choice but if my gasket breaks id be sol
« Reply #23 on: March 03, 2011, 11:24:27 AM »
If you used a gasket material that is good for use in gasoline service no need to do anything to the now dry side of the assembly. I'm been running this way for over three yrs. If gasket start to leak out weep hole on bottom of dry side then you know you have a problem. If you want a fuel shut off, get an electric valve and wire it to a keyed 12volt source so as soon as key is turned off valve is closed and no hydro if you forget to close manual valve. Some people have wired these thru the tilt switch so if bike is layed over the valve will shut fuel off.
« Reply #24 on: March 03, 2011, 11:26:29 AM »
Sorry should have said inline ( placed in fuel line)electric shut off valve.
« Reply #25 on: March 03, 2011, 12:20:24 PM »
you gotta bigger pic of that Steelers girl?  Evil
Mildew
Auburn, Ga
« Reply #26 on: March 03, 2011, 01:38:18 PM »
Lol
« Reply #27 on: March 03, 2011, 02:19:08 PM »
Lol
Ah my firewall at work blocked it.  tickedoff Just a white pic on my end. Dang it!
X Ring
VRCC #27389, VRCCDS #204
« Reply #28 on: March 03, 2011, 03:24:12 PM »
Lol
Sent it to you via email.
Marty
« Reply #29 on: March 03, 2011, 04:22:24 PM »
Lol
Marty
Rocketman
Seabrook, Texas
« Reply #30 on: March 04, 2011, 02:03:54 PM »
I've resisted for a few days, but can't hold back anymore:
Should you really start a discussion of "Pet Cocks" by telling us you have 2000 STDs?  I didn't even know there were that many STDs out there!
