March 22, 2026, 08:21:12 AM *
Author Topic: Rear wheel hub flange  (Read 893 times)
shank
Morristown TN.
« on: February 25, 2011, 03:54:06 PM »
Can anyone tell me if all the real wheel hub flanges for valkyries are the same part?
NITRO
Eau Claire, WI
« Reply #1 on: February 25, 2011, 04:12:35 PM »
Should be. If in doubt, check out HDL and look at part numbers.
When in doubt, ride.
Ken Tarver
North Mississippi
« Reply #2 on: February 25, 2011, 08:29:32 PM »
if i understand you correctly......i just put a '97 drive flange on a '03 chromed wheel; the chromer chromed the hub, so i had to grind that off the hub. otherwise it worked. i also put the brake rotors off my '97 wheels onto the the '03 wheels, that was a miss match i found out later, but i got it worked out and all is good now.
Ken
