February 02, 2026, 03:09:33 AM *
Author Topic: AUX Fuse block control connection point  (Read 1822 times)
Hotrodwing
Clarks Summit PA
« on: February 28, 2011, 03:13:42 PM »
I am in the process of hooking up an aux fuse block for add equipment and was wondering where to tie into the spare fuse circuit.  There are wires running from the back side of the spare fuse  location but they get lost in the wire loom.  I have a 97 standard and was wonder if anyone taped into near the block or knew where the wires ran to?  Thanks  Mike
« Reply #1 on: February 28, 2011, 04:13:39 PM »
Under the right side cover is a boot with 2 small connectors. This is the aux fuse circuit. This is where you tie in the contacts for the relay. Main power should come off the battery directly and have an appropiate size fuse for the extra fuse panel. When you turn the key off, the aux panel will drop out too. Check "Shop Talk". I think a diagram is in there. It's been a long time since I looked for it.
Hotrodwing
Clarks Summit PA
« Reply #2 on: March 01, 2011, 03:47:42 AM »
Got it. Thanks cooldude
us385south
"Geeky White Caucasion"
San Marcos, Texas
« Reply #3 on: March 01, 2011, 06:56:56 AM »
Check this: http://culleynet.com/?page_id=1116
"I can't explain a blessed thing,
not a falling star or a feathered wing,
but when the light's just right I swear I see...
poetry!"
Hotrodwing
Clarks Summit PA
« Reply #4 on: March 01, 2011, 06:37:05 PM »
Thanks that is almost identical to what i did. i guess great minds think alike Grin
