November 22, 2025, 02:46:11 PM
ANOTHER TACH ISSUE
Topic: ANOTHER TACH ISSUE (Read 1238 times)
UTAH INFANTRY
Kaysville, Utah
ANOTHER TACH ISSUE
March 01, 2011, 03:46:52 PM »
I HAVE READ THE POSTS AND TRIED THE GUIDANCE GIVEN BY MANY. BUT I STILL HAVE NOT FOUND THE SOURCE OF THE PROBLEM. I HAVE CHECKED THE TAIL LIGHT, AND CHECKED THE FUSE. I DO NOT HAVE MAGNET TANK BAGS/POUCHES.
WHEN THE BIKE IS OFF THE NEEDLE SITS WHERE IT IS SUPPOSE TO. WHEN I TURN THE IGNITION IT IS WHERE IT IS SUPPOSE TO BE. BUT WHEN I START IT UP, THE NEEDLE JUMPS TO 3K, AND WHEN TURNING THE THROTTLE THE NEEDLE MOVES ONLY SLIGHTLY. WHEN SHUTTING OFF THE IGNITION THE NEEDLE PAUSES, THEN SLOWLY RETURNS TO ITS PROPER REST POINT.
HAS ANYONE HAD THIS SAME ISSUE?
Recce 1-12INF 4BCT 4ID
Operation Enduring Freedom
1986-Jessica Rae Leota-2012
All my Love All my life
X Ring
VRCC #27389, VRCCDS #204
Re: ANOTHER TACH ISSUE
March 01, 2011, 04:14:10 PM »
Your tach may be hosed and need replacing. Iirc, there is one on ebay now.
Marty
olddog1946
Moses Lake, Wa
March 02, 2011, 08:10:29 AM »
Does indeed sound like a toasted tach..and ditto on the tach on ebay.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
Moses Lake, Wa. 509-760-6382 if you need help
=> InZane XXV
