February 01, 2026, 10:28:59 PM *
Author Topic: Carb Sync - "bouncing" readings ???  (Read 2269 times)
F6CTrider
Denver, Colorado
« on: March 05, 2011, 04:28:15 PM »
Just learned how to, and did a carb sync this am with my neighbor (Thanks HC!).  While we adjusted the carbs the vac reading was bouncing up and down.  This was not the experience when my friend did his bike.
Any experience with this out there?   Is there another issue to pursue?  I am now replacing a few of the overly cooked vacum caps to keep away from any leaks soon to be developing.
Perhaps my carbs have a nervous condition?
LAnthony
« Reply #1 on: March 05, 2011, 04:49:21 PM »
My set has little in line reducers on each of the lines that you tighten up just enough to stop the bouncing.  The mercury ones don't seem to bounce as much as the guage ones do.  This is just the intake valve opening and closing, reducing vacuum readings for a split second.
« Reply #2 on: March 05, 2011, 06:19:52 PM »
I went to the hardware and bought a brass needle valve. Hooked it up between carn and gauge. I slowly close it till it stops bouncing. easy $5 fix.
bigfish_Oh
Allis
West Liberty,Ohio 43357
« Reply #3 on: March 05, 2011, 07:24:26 PM »
Is everyone using liquid filled guages ? I still have access to 6 tubes of mercury(I traded to my brother), but have saw on other sites the homemade tubes with ATF . I think I will make a set first just for the cheap challenge/test !
My PMS is getting bad
2012 HD Road King Classic, Teq sunrise/HD Orange
2009 HD Nightster,orange
1974 CB550F,org
1999 Valkyrie,orange/Black (20K)
2009 GMC 3500 Duramax CC Dually 4wd (new)
1957 WD45 Allis Chalmers Grandpa bought new
1982 CBX (new)
1980 CBX (6K)
1979 CB750F (new)
1958 Lambretta TV175 (Dad's new)
4
« Reply #4 on: March 06, 2011, 04:50:20 AM »
You make it over to Indy?
bigfish_Oh
Allis
« Reply #5 on: March 06, 2011, 08:36:00 AM »
We went over, I liked it better than the columbus indoor easyriders, I'll still give an outdoor easyriders a go !! I saw a couple things of interest, Rebecca tried on a jacket she liked, then I ordered the same one when we got home that she doesn't know about yet($30. less). I bought more raffle tickets, I better quit, I can't afford the income tax on 4 new Harleys !!!
1974 CB550F,org
1982 CBX (new)
1980 CBX (6K)
1979 CB750F (new)
4
« Reply #6 on: March 06, 2011, 02:34:24 PM »
I guess I need to know what you mean by bouncing.. If the gauge doesn't have any provision for dampening[  pinch screw ], then you can just add one.. A little valve or forceps will do, all you need to do is cut down on the pulsations, pinch or restrict the line until the needle just barely wiggles..
highcountry
Parker, CO
« Reply #7 on: March 06, 2011, 02:45:27 PM »
I did F6CTrider sync with my Twinmax and the needle would vibrate instead of remaining steady.  When I did my bike about 6 mos ago, I don't recall the needle vibrating but I have slept about 180 nights since I did it, maybe I forgot. uglystupid2  It was easy to center the needle even though it was vibrating.  It did the same on all cylinders.  I was wondering if there was some kind of vacuum pulsing going on.  F6CTrider's bike does have a 6 degree ignition wheel and mine does not.
