February 02, 2026, 12:07:48 AM *
Author Topic: Lowering Kit?  (Read 7001 times)
BigBishop
God Bless. Ride Safe!
Spring, TX
« on: March 06, 2011, 08:28:46 PM »
Anyone know anything about a Lowering Kit for a 99 Valk.
I'm interested in Lowering my bike.
Any thoughts on this out there?
Armando...
Mr.BubblesVRCCDS0008
« Reply #1 on: March 07, 2011, 12:23:57 AM »
You can go to a shorter rear shock, shorter rear tire, and you can slip the front tubes in the triple tree about 3/4  of an inch. That's about all I know you can do. Remember the lower you go the easier it is to drag your pegs and bottom out the shocks and rub the top of the tire up in the rear fender.
RP#62
Gilbert, AZ
« Reply #2 on: March 07, 2011, 04:26:54 AM »
You can also trim some foam out of the seat and narrow the front of the seat pan.
-RP
RUDE DOG - Steelers
New Jersey - VRCC # 3966
« Reply #3 on: March 07, 2011, 07:53:09 AM »
I lowered my rear with 11.5 inch Progressives and a lower profile car tire.  Initially I slipped the forks 5/8's of an inch.  I eventually went with a 6 degree rake kit which gave me the look I wanted.  I think Im about as low as you would want to go.
mirion
1997 Std - 2000 IS
Frankenmuth, Michigan
« Reply #4 on: March 07, 2011, 09:14:26 AM »
Like Steelers, I went 11.5 Progressives and 6 degree front rake. Passenger and I total out at 300 and it is still a good ride with a rare bottoming out on a big bump.
GJS
Today is the tomorrow you worried about yesterday.
Vancouver Island, BC, Canada
« Reply #5 on: March 07, 2011, 06:51:30 PM »
Like others here, I also wanted a lower ride. I am 5'10" with a 30" inseam.
After much fussing about I ended up doing the 6 degree rake.
11.5" progressive shocks and a Corbin seat.
As well, the slightly smaller rear car tire.
I love having both feet flat on the ground when I'm at an intersection.
The only negative is my floorboards are a little worse for wear. Definitely can't corner as aggressively as I used to.
I'm not aware of any 'kits'.  For sure I would not slip the tubes, that will compromise the integrity of the front end under any severe load. I'm sure it would work perfectly 99% of the time, but I'd never want to experience that failure.
Good luck
The tragedy of life is not that it ends so soon, but that we wait so long to begin it.
- W. M. Lewis
larryh0841
« Reply #6 on: March 08, 2011, 09:46:39 AM »
If you go to the shop talk section and look up Lowering Valkyrie Forks you will find a safe method to lower the forks on the Valkyrie.  I submitted this article in 2001 and have over 75,000 miles on the initial installation with no problems.  You can send me an email if you have any problems performing or understanding the directions and I will assist in any way I can.      Larry
« Reply #7 on: March 09, 2011, 05:50:26 AM »
TNT, over on the BBB has been running her valk for a very long time with the forks slipped down.  You might go that board and give her a shout.
BigBishop
Spring, TX
« Reply #8 on: March 09, 2011, 11:49:18 AM »
Thanks for the help and information guys....  cooldude
Armando...
