February 01, 2026, 10:29:25 PM *
Author Topic: Rear wheel spacer?  (Read 1823 times)
Mr.BubblesVRCCDS0008
« on: March 07, 2011, 07:45:12 PM »
 I was digging in a box of junk the other day and found a rear wheel spacer for a 94, 1500 goldwing. Is this the same as the valks, it sure looks like it is the same and if it is I've gonna cut it do so next tire service I can go to the 5204 sealed bearing replacement on the left side. I don't have the mics to check it out but the axle looks the same in dia. and the spacer looks about the same length as the valks.TIA
Warlock
Magnolia, Ms
« Reply #1 on: March 07, 2011, 08:33:38 PM »
Same one as the Valkyrie.
David
« Reply #2 on: March 08, 2011, 08:48:25 AM »
That particular spacer is not such a consequential part that you need a micrometer to measure it.
Put one along the other and you will be able to tell (feel) if there is any difference.
Thinking that way (close tolerance) would necessarily mean that the swingarm is also built to the same close tolerances and it is simply a welded structure and not able in it's configuration to be built in such a way!
Warlock
Magnolia, Ms
« Reply #3 on: March 08, 2011, 11:20:40 AM »
Why bother to look when they both share the same P/N
David
« Reply #4 on: March 09, 2011, 05:47:39 AM »
Thanks I did want to pull my to measure  and I figured that someone on the board had been there done that before.
