May 02, 2026, 06:17:46 PM *
Author Topic: rear wheel spacer?  (Read 1226 times)
Mr.BubblesVRCCDS0008
« on: March 07, 2011, 07:48:19 PM »
I was digging in a box of junk the other day and found a rear wheel spacer for a 94, 1500 goldwing. Is this the same as the valks, it sure looks like it is the same and if it is I've gonna cut it do so next tire service I can go to the 5204 sealed bearing replacement on the left side. I don't have the mics to check it out but the axle looks the same in dia. and the spacer looks about the same length as the valks.TIA
keepinon
New Caney, Tx
« Reply #1 on: March 08, 2011, 07:06:01 AM »
I checked part numbers for a '98 Aspencade that I had wrecked out, vs my '97 Standard, they were the same.
42313-422-000  Honda calls it a collar...
1998 GL1500 CT Trike
« Reply #2 on: March 09, 2011, 05:36:32 AM »
Thanks for the reply as now I don't have order one just to cut down for the conversion.
