February 02, 2026, 12:07:49 AM *
Author Topic: Bolt Question (Rear Exhaust Hangers / Rear Peg plate)  (Read 1518 times)
Medic
Rural Hall, NC
« on: March 07, 2011, 10:51:18 PM »
1. Can someone tell me the part number for the two bolts that mount the exhaust to the frame (rear peg plate to frame)
2. Can you also advise if yours are chrome or black.
I had one come loose and work its way out. The ones on my Valk when I got her from the original owner were chrome. When I ordered new ones, they were the right size but black and had a different head. Thought maybe the original owner was using aftermarket ones, but the black just doesnt look right.
The fiche pic is hard to decipher to me on deciding which part to order, so maybe I ordered the wrong thing.
PhredValk
Edmonton, Alberta, Canada
« Reply #1 on: March 08, 2011, 01:48:53 AM »
I don't know about part numbers, but if you took what you have to a nut and bolt supplier they should be able to sell you the same bolt in a variety of chrome heads, and probably a lot cheaper than Honda...
Fred.
VRCCDS0237
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #2 on: March 08, 2011, 02:48:20 AM »
medic.....1997-1999 those bolts were black (part # 90102-MJO-000.  years 2000-2003 were chrome (part # 90109-KN8-730).  the bolt size is:  10mm x 16mm.
Medic
Rural Hall, NC
« Reply #3 on: March 09, 2011, 12:01:46 AM »
Thanks, thats what I needed...looks like the original owner did use after market bolts.
9Ball
« Reply #4 on: March 09, 2011, 04:11:09 AM »
If I remember correctly, the I/S came with chrome bolts and the standards/tourers had black bolts.  This was also year-specific, 2000 seems to ring a bell.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
