March 22, 2026, 11:47:46 AM *
Author Topic: Rear wheel spacer  (Read 1400 times)
rainman
Steve ( rainman) Eads
Bloomington Indiana
« on: March 08, 2011, 07:21:14 AM »
Changed the left rear wheel bearing last fall and setting around this winter was thing about the rear wheel spacer. crazy2 My question is does this spacer have to be their? And what does it do? Besides making it harder to get the left bearing out. Looks like there is too much slop from side to side to be a spacer. Has anyone taken it out? And if so have you had any problems?
X Ring
VRCC #27389, VRCCDS #204
« Reply #1 on: March 08, 2011, 11:38:07 AM »
Which spacer are you talking about?  The one inside the wheel or the one between the left wheel bearing and the frame?
Marty
Jack
Benton, Arkansas
« Reply #2 on: March 08, 2011, 11:44:01 AM »
either way, spacers are there for a reason.
bigvalkriefan
On the green monster
South Florida
« Reply #3 on: March 08, 2011, 12:21:15 PM »
I doubt very seriously that the Honda engineers would have a part in there that wasn't necessary.
.....say to those with fearful hearts, "Be strong, do not fear; your God will come, he will come with vengeance; with divine retribution he will come to save you."
Isaiah 35:4
I know who wins in the end.
rainman
Bloomington Indiana
« Reply #4 on: March 08, 2011, 12:48:00 PM »
Marty
the spacer that goes inside the wheel
Duffy
Atlanta, GA
« Reply #5 on: March 08, 2011, 12:51:17 PM »
I am no mechanic - the Tech board could vouch for that!  Cheesy
But I think removing the spacer would mess up the drive shaft alingment pretty quick.  Undecided
Scott in Ok
Chief Worker Ant
Oklahoma City, Ok
« Reply #6 on: March 08, 2011, 12:57:45 PM »
The spacer inside the wheel is there for a reason.
It takes up the space between the two bearing inner races making it one solid piece(when combined with the rest of the rear end).  Without it, the bearings would last until you torqued the axle nut, and that would be the end of them(or soon thereafter).  Bearings of that type aren't designed to have any side load.
-Scott
Highbinder
Bastian/Tazewell,VA.
« Reply #7 on: March 08, 2011, 02:30:09 PM »
That's referred to as a thrust washer and does have a purpose....while out in Washington State I had a flat tire and had a dealer replace the tire and he left the thrust washer out and I rode the bike all the way back to Va.  When I got home I noticed alittle play in the wheel and decided to pull it....it had damaged the inter hub and rubbed the backside of final drive flange...and I had to replace the wheel... I probably could have just put 2 thrust washers in, but decided to just replace the wheel.....put it back in.... cooldude
rainman
Bloomington Indiana
« Reply #8 on: March 08, 2011, 03:04:07 PM »
thanks Scott and Highbinder I did put it back in but I know how the auto manufacturers do some things but what you guys say make sense.
Thanks  cooldude
