March 22, 2026, 12:57:30 PM *
Author Topic: difference between 98 and 02 Valkryie  (Read 2670 times)
Snoopy
multi year nam vet AC130 (puff)
Jacksonville Beach, Fl/ Pickens,SC
« on: March 08, 2011, 02:31:19 PM »
What are the difference between a 1998 and 2002 Valkyrie standard
Multi year nam vet AC130 (Puff) All gave some, some gave all
« Reply #1 on: March 08, 2011, 02:35:49 PM »
The tank emblem, and the '02 will have a chromed radiator hose covering, the '98 has a blacked out one...
I'm sure there are a few other small things like that, but mechanically they're the same thing... As I recall, only the '97's have anything mechanically different about them (The carbs were different in '97 I believe...)
laserpat
Cedar Park, Texas
« Reply #2 on: March 08, 2011, 02:58:29 PM »
I think the seat changed a little in 2000
« Reply #3 on: March 08, 2011, 02:59:51 PM »
When did the polished wheels come into effect?
« Reply #4 on: March 08, 2011, 02:59:59 PM »
Serk-just as an aside-april 21 2011 9 years smoke free. Well done to you sir. coolsmiley
rrmdeuce
Los Angles
« Reply #5 on: March 08, 2011, 03:14:21 PM »
Bold new graphics. Smiley
Jess Tolbirt
White Bluff, Tn.
« Reply #6 on: March 08, 2011, 03:25:15 PM »
front wheel beARINGS ARE DIFFERENT
Valkyrie member # 23084
« Reply #7 on: March 08, 2011, 03:30:31 PM »
Congrats to you! And thanks!
Yeah, the wheels got shinier, the seat got slightly less sucky (If any of 'em actually have stock seats anymore?) and the bearings got changed...
I'm sure there are a few other small things, but they're minor... (Someone please pipe up with the other things that changed, now I'm wracking my brain trying to remember!)
Six Guns
Fort Worth, Texas
« Reply #8 on: March 08, 2011, 03:55:18 PM »
I my 98 Tourer I had made in the USA stamped on the passenger rear seat. Didn't they remove that on later year valks?          uglystupid2
« Last Edit: March 08, 2011, 03:56:57 PM by Six Guns » Logged
Dave Weaver
Seymour, IN
« Reply #9 on: March 08, 2011, 04:46:38 PM »
4 years
Do unto others as you would have them do unto you.
T.P.
Apple Valley, Minnesota.
« Reply #10 on: March 08, 2011, 05:58:26 PM »
I thought that the 97's were the ones that had the different front bearings.  ???
98's through 03 should be the same
SteveL
« Reply #11 on: March 08, 2011, 06:16:04 PM »
From Dag's site
http://www.valkyrienorway.com/MODEL%20DIFFERENCES.html
Engine:
• “Made in USA” no longer appears on engine.
• Engine Coolant Temp Indicator Unit eliminated (sensor now
directly controls LED).
Frame:
• I/S -style turn signals (no screws in lense face).
• New Seat design (I/W ‘97-’99).
• Seat height changed to 28.9” from 29.1”.
• Chrome wire wrap added to lower radiator hose.
• “Made in USA” no longer on rear seat.
• Tank badge changed from “F6” to Maidenhead design.
• Heavier rear brake rotor (caused different wheel, caliper
bracket and rotor mount bolts).
• Extra protective boot on start relay.
• Polished rear transfer case.
• Lower triple clamp P/N change.http:
2001
  Polished & clearcoated wheels
• Front wheel is only machined
outside of brake rotor shadow.
« Last Edit: March 08, 2011, 06:33:50 PM by SteveL » Logged
SteveL
« Reply #12 on: March 08, 2011, 06:17:46 PM »
It's only an opinion but it has been mentioned more than once that the 97s and 98s had more torque. I have ridden my 98 and many 99s and up and believe it is true. (but that's just a opinion without any explanation)
sheets
Jct Rte 299 & 96, Calif.
« Reply #13 on: March 08, 2011, 06:35:52 PM »
If I remember correctly... the face of the horn was black on 97 - 98.  In 99 the horn was chrome plastic. Still in the same funky spot.
Big Rig
Woolwich NJ
« Reply #14 on: March 08, 2011, 07:01:33 PM »
4 years
Dang, beat me to it! 2funny cooldude
olddog1946
Moses Lake, Wa
« Reply #15 on: March 08, 2011, 07:47:02 PM »
I'd bet the 02 cost more as well...
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
Redline +
Northwest Washington
« Reply #16 on: March 08, 2011, 09:47:01 PM »
The 2002s are prettier.  cooldude
I still need an updated photo.
Redline  Cool
PhredValk
Edmonton, Alberta, Canada
« Reply #17 on: March 08, 2011, 10:24:55 PM »
99-01 added the Interstate model. Not what you asked, but there it is.
Fairing, trunk, radiator mounted air deflection pods with a foglight option, different ICM and carb springs, single molded front/rear seat. Cooling air scoops under the engine guard.
Interstate models intended for the Japanese market had the Goldwing reverse gear, US and European models did not.
Redline, where is that pic?
Fred.
« Last Edit: March 08, 2011, 10:33:44 PM by PhredValk » Logged
VRCCDS0237
Redline +
« Reply #18 on: March 09, 2011, 09:12:23 AM »
Fred.
The photo above is Westbound on Highway 12, at Lolo Pass, near the Idaho/Montana State line.
Redline  Cool
« Reply #19 on: March 09, 2011, 09:30:04 AM »
You is absolutely right T.P. but don't tell no one.
There is very very little difference in these years.   NO improvements if that is what you are looking for.
junior
new hampshire
« Reply #20 on: March 09, 2011, 10:04:53 AM »
the 97s also has a differant cam it was a higher lift on the lobes
Redline +
« Reply #21 on: March 09, 2011, 12:09:35 PM »
Don't remember ever hearing this before.  ???
Redline  Cool
Dag
Country Rep. Norway
« Reply #22 on: March 09, 2011, 12:25:36 PM »
Redline  Cool
I just love that color....   cooldude
Redline +
« Reply #23 on: March 09, 2011, 01:19:30 PM »
Redline  Cool
Thanks Dag, I love it too! I'm told it's one of the rarer Valks.
Redline  Cool
Jess Tolbirt
White Bluff, Tn.
« Reply #24 on: March 09, 2011, 01:31:16 PM »
oops that was my bad,,,guess i had a brain fart, i have a 97 and he asked about 98's...
junior
new hampshire
« Reply #25 on: March 09, 2011, 02:04:09 PM »
Redline  Cool
scope out the micro fiech and the 97 has a diferant part# than the newer ones
