greggh
« on: March 12, 2011, 06:12:17 PM » |
So I bought this mighty Vac from harbor freight to flush the master cylinders and clutch. So I have it hooked up to the clutch bleeder and get through 3/4 of the cylinder, close the bleeder and fill the cylinder and go to do it again anthe mighty vac starts leaking.
Has anyone ever had an issue of this nature with these vacs. The clutch leverl is limp with no pressure otherwise I would just pump it out maunally.
Any thoughts or Ideas?
TIA Greggh
« Reply #1 on: March 12, 2011, 06:26:18 PM » |
Why did you close the bleeder to refill the cylinder?
Where did the Mighty Vac leak. hose, plastic tube or main tubing of it?
Possible the vac is faulty, but undoubtful.
However, if it came from Harbor Frieght, it could be a reject, they buy all rejects from their suppliers..
greggh
« Reply #2 on: March 12, 2011, 06:29:37 PM » |
How are you RJ. It started leaking from the vac unit. I closed the bleeder just for assurance reasons. I supposse Harbor freight will give me grief when I try yo echange without a reciept. I do however have my online bank debit transaction.
« Reply #3 on: March 12, 2011, 06:31:04 PM » |
It's worth a try.......
Print out your online transaction for proof.
greggh
« Reply #4 on: March 12, 2011, 06:34:27 PM » |
Yep I already have it in black and white. Was trying to get the basic maint done for this years riding. I have put about 41k on it within the last 3 years and plan do put alot more on it this summer!
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #5 on: March 12, 2011, 06:47:53 PM » |
greggh.... there is a good chance that harbor freigh is only going to want to exchange it for another reject, in which case go to sears and get yourself the one they sell in the red blowmolded case. it runs about $60.00, which in the long run will still pay for itself in short order. good luck.
« Reply #6 on: March 12, 2011, 07:17:02 PM » |
I got one from auto zone that was $20 or so. Has a boat load of fittings for all sorts of stuff.
RonW
« Reply #7 on: March 12, 2011, 07:24:49 PM » |
 Speed BleedersĀ® worked for me. I suspect that Mighty Vac is only as efficient as the model you purchase.
2000 Valkyrie Tourer
Bobbo
« Reply #8 on: March 12, 2011, 10:00:37 PM » |
Is this the handheld unit with a collection bottle?
If so, did you draw brake fluid into the pump?
greggh
« Reply #9 on: March 13, 2011, 11:30:46 AM » |
@ - Bobbo Yes and Yes. So using the same vac before returning I Hooked everything together and did a dry run ( no fluids at all ) and it held the vacume just fine. Hooked all of it to the clutch and strated the same procedure again and this time everything worked fine. The only thing I did different was shorten the hose from the canister to the pump. Clutch seems to have the same resistance it had before I started all this. So now I will do the front brakes and see how that turns out. I will post more later.
greggh
« Reply #10 on: March 13, 2011, 12:54:13 PM » |
A Valk owner and his Mighty Vac! Not sure what I did wrong the first time But the second attempt was a success. The clutch, front and rear brake fluids have been changed and all appears to Function properly  I am going to fire it up and take it for a short run to be certain. The Mighty Vac seems to be ok I believe the problem was within the hands of an inexperienced user.
greggh
« Reply #11 on: March 13, 2011, 04:06:08 PM » |
SUCCESS!
greggh
« Reply #13 on: March 13, 2011, 04:47:29 PM » |
Well Let see. Here is the hit list I ahve made for my Valk. Fork Fluid Adjust Valves Sync the Carbs - Friend of mine will be doing that rear wheel bearings - inspect front they are a year old. Differential fluid Clean & Lube splines and rear axel Check the stearing head bearing Clean the air filter Lube the throttle cables and all other cables as needed That should about do it. Oh then get on it and Ride Like I Stole It. Thanks to for your input.
