January 28, 2026, 11:22:51 AM *
Author Topic: IS Ignition Module on a Std Valk  (Read 2872 times)
Sasha47VSSS
Malo les Bains, France
« on: April 10, 2009, 10:36:07 PM »
I've accquired the IS Ig.Module and intend to installit on my Std Valk. Is anything else required, except simple connecting? Any adjustment of the carbs?
Udo
Germany, Krefeld
« Reply #1 on: April 11, 2009, 04:36:33 AM »
No, it´s plug and play. The rubber boot for the IS is a bit larger, cause the module is larger, but it does fit in the Standard / Tourer boot.
Bagger John - #3785
« Reply #2 on: April 11, 2009, 07:18:22 AM »
Now put a set of I/S carb springs in...and either shim the stock needles slightly or remove and replace with a set of DynoJet adjustable needles.
YMMV, but mine actually went up a few MPG...and the grin factor definitely did, especially when the motor is being revved under load from 1700-4000RPM. Much more responsive... cooldude
