March 22, 2026, 06:26:34 PM *
Author Topic: St. Louis Wrench Party  (Read 1662 times)
Joe Hummer
Arnold, MO
« on: March 13, 2011, 01:23:56 PM »
I am planning on holding a wrench party on March 26th.  My planned activities is replacing my timing belts (and possibly putting on a new timing wheel), rebuilding my alternator (brushes and bearings), and replacing my front springs (got progressives for christmas).  If anyone would like to come along and watch these maintenance functions in action, drop me an email at JoeValkIS@Spirit-1100.com or a private message on here.  Also, if you have something you would like done or help with, feel free to let me know.  If I can't get to it, I am sure that someone else at the party would be able to help or you can use my tools.  Let me know.
Joe
1999 Valkyrie Interstate
blackcat
Nicholas Vore VRCC # 30301
Mounds, Arkansas
« Reply #1 on: March 13, 2011, 06:27:59 PM »
bump
______________________
03 Standard -Fast Black
00 Interstate - Red/Black
97 Tourstate - Yellow/Ivory
2010 Goldwing - Pearl Yellow
« Reply #2 on: March 14, 2011, 02:10:09 PM »
Still thawing out from the last one.  Cheesy
Would be nice to see everyone again. Lotta good people there last year.
Joe Hummer
Arnold, MO
« Reply #3 on: March 15, 2011, 03:58:32 PM »
Bump...
Joe Hummer
Arnold, MO
« Reply #4 on: March 17, 2011, 06:54:31 PM »
Bump
Joe Hummer
Arnold, MO
« Reply #5 on: March 19, 2011, 05:34:01 AM »
Bump
chip
« Reply #6 on: March 19, 2011, 07:03:35 PM »
Joe, I'll be there Sat, Lets use your bike to learn on, because I need to do the belts, and would like to install Progresives in the front on mine next.
blackcat
Mounds, Arkansas
« Reply #7 on: March 23, 2011, 08:44:58 PM »
bump
Joe Hummer
Arnold, MO
« Reply #8 on: March 26, 2011, 05:01:39 PM »
Who would have thought that it would be snowing in St. Louis today???!!!  We have gotten 2-3" so far and it is still coming down...but that didn't stop me and a couple of friends (caged it) from working on my bike.  Chip and John...thanks for your help and I hope you guys learned something today...I know I did.
We started with the progressive springs.  All went very well with it...in fact, I was surprised at how simple the task was.  (A special thanks to Lyn-Del for the use of the fork tool.)  And I was dumbfounded by the color of the oil.  Let me explain...a few years ago, I had my stealership rebuild my shocks because of leaking forks.  I would have thought they would have had to replace the oil when they did the seals...but after looking at the oil, there is NO WAY it was changed.  Filled the tubes with new oil after draining the old gunk out.  Buttoned the forks up and set them aside.
Before putting the front end back together, we went ahead and changed the timing belts.  Absolutely no problems there...that was an easy task.  Had planned (and was told that the Standard/Tourer trigger wheel was different than the IS wheel) to put in a 4 degree wheel but when I checked the one I got from a friend, I found it to be exactly the same (so either I was told wrong or my friend had an IS wheel and didn't know it)...no offset at all...so I left the old one in.  I may revisit this after ordering a 4 degree wheel later.  Spun the motor prior to putting it the cover back on to make sure it all worked.  Buttoned her up and started the motor...just to make sure.
We put the front end back together and after saying bye to Chip and John, I started working on the alternator.  I didn't have a lot of trouble getting it out.  I think I just got lucky.  Cheesy  Took it to the work bench and tore into it.  Brushes were about 1/2 way work but the nose bearing had a growl in it.  I went ahead and changed the brushes and bearings since I had it apart.  Putting it back in wasn't as easy as getting it out but I got it back in there.  Buttoned everything up and gave it a try.  A steady 12.7 volts at idle and a little over 14volts at 2k.  Sounds good to me. Cheesy
Nothing like spending a snowy day in the garage with friends, a fat lady, and of course...a heater.  Cheesy
I am going to try to plan another wrench party in a month or so.  It will depend on work though...so watch the forum for the date.
Joe
« Reply #9 on: March 26, 2011, 07:04:35 PM »
I'm glad you guys got to do the wrench party. I was kicking it around-but got up to freezing rain and wind. uglystupid2 Sides-nice and warm in the house and by the time i made my coffee decided to stay at lacasa today. Hopefully the next one will be snow free. 2funny RIDE SAFE. angel
« Reply #10 on: March 27, 2011, 08:09:04 AM »
Saw the radar and was GLAD I didn't make this one!  Cheesy 34 deg windy but sunny up here. Spent half the day at a tattoo convention.  crazy2
