November 22, 2025, 01:30:20 PM *
Author Topic: Fuel Shut Off  (Read 1457 times)
TGViper
« on: March 15, 2011, 09:58:32 AM »
Ok - stupid question maybe but I am going to ask anyway.
If the stock shut off valve is prone to not work after some time, can't I just put a manual shut off valve prior (or after) to the stock valve and not have to do the pingle?  Splice it right into the fuel line?
TGViper
Just
Bobbo
Saint Charles, MO
« Reply #1 on: March 15, 2011, 10:04:48 AM »
If the stock diaphragm develops a vacuum leak, it will shut off the gas flow no matter what you add to it.
TGViper
« Reply #2 on: March 15, 2011, 11:37:18 AM »
I see.  Would what I am proposing doing help to prevent hydro lock (leaking past the carb float)?
« Reply #3 on: March 15, 2011, 11:58:16 AM »
If I understand what you're saying... you're proposing to install a manual shut-off valve someplace that
makes the OEM valve extraneous... if you're going to get a manual shut-off valve anyhow, it seems
like the easiest (also - reversible, in case you're wondering about that) thing to do is unscrew the
OEM valve from the tank, and screw in a Pingel...
Red Diamond
Beaumont, Texas
« Reply #4 on: March 15, 2011, 12:13:38 PM »
The Valk owners that like Pingles will tell you to throw away the OEM valve. The Valk owners who know that the petcock is not the cause of hydro-lock will advise you to rebuild the original one or get a new one if you feel that it has been on there long enough. It's not that expensive and the rebuild is neither expensive or difficult.
« Reply #5 on: March 15, 2011, 12:21:57 PM »
I think a faulty float needle can cause a fuel-lock, however, a faulty petcock will just add to the problem.. An extra in-line shut-off may help, but, how are you going to get at it easily enough to actually use it.. The best prevention for the dreaded fuel-lock is a filter..
TGViper
« Reply #6 on: March 15, 2011, 01:52:55 PM »
Thank you all....
