March 22, 2026, 03:55:51 PM *
Author Topic: another gun question  (Read 3315 times)
sugerbear
wentzville mo
« on: March 15, 2011, 09:11:05 PM »
any comments on this holster?
i never tuck my shirt in (i'm a t shirt kinda guy)
http://masterofconcealment.com/pgroup_descrip/296_IWB+Holsters+Concealment/7117_Tuck-This/?return=%3ftpl%3Dindex%26category_id%3D296%26_IWB%2BHolsters%2BConcealment%2F
thanks
X Ring
VRCC #27389, VRCCDS #204
« Reply #1 on: March 15, 2011, 09:21:06 PM »
With any concealment holster, you get what you pay for.  That being said you need to be able to holster the weapon without using your other hand to open the holster.  IOW, the holster must NOT collapse when you remove the pistol.  Desantis is an excellent brand and has an outstanding reputation.  Still, I would have to call them and ask these questions before I purchased.
That being said, my preferred concealment holster is a Blackhawk CQC Serpa.  One other thing you need to be aware of is with in the waistband holsters, you need to wear pants about 2 inches bigger than your waist so you have room for the gun.
Marty
Ratdog
Somewhere out West, Which way did I go?
« Reply #2 on: March 15, 2011, 09:23:35 PM »
No experience with that model... however, I do like the DeSantis brand of holsters.
Make yourselves sheep, and the wolves will eat you. - Benjamin Franklin. If it ain't Zesty, it's only a two-tone.
sugerbear
wentzville mo
« Reply #3 on: March 15, 2011, 09:35:27 PM »
thanks x-ring, i didn't know that!  maybe i should not look at the iwb holsters.
i'm a LARGE guy 6 ft 360 lbs have a 54 in waist and wear a 3x-4x t-shirt.
which holster would you recommend from that site?
h yea i have a springfirld xd 40 4 in
« Last Edit: March 15, 2011, 09:38:59 PM by sugerbear » Logged
X Ring
« Reply #4 on: March 16, 2011, 06:13:50 AM »
Sugarbear, with your size you're going to need to try holsters to find one that works.  I would recommend a strong side holster that does not collapse when you draw the weapon so you can reholster without having to get you non gun hand in the way to assist.  Also you need to look at your belt.  You need to get a heavy duty or reinforced belt so the butt of the weapon doesn't lean out from your body and announce to the world you're carrying.  In addition, it could cause the butt of the weapon to bounce.  I would wear the holster behind the side seam of your pants so the weapon and holster fit into that hollow area of your butt.  It's a natural area to help you conceal the handgun.  If you intend to carry as a lifestyle choice, you're going to probably end up with a box of holsters that you've tried and discarded.  I told you what I use.  The Blackhawk CQC Serpa.  Mine are made of carbon fiber; however, Blackhawk makes a polymer version that is about $25.  It would be good to try then, if you like it, you can move up to the carbon fiber version.  It has more options like belt loop or paddle that you don't get with the polymer version.
Marty
« Reply #5 on: March 16, 2011, 06:34:05 AM »
Besides what Marty said, I can only say that big guys have more trouble wearing IWB holsters comfortably than thin guys.  Just the nature of the beast.  Riding or driving with them on can be troublesome to painful.  I use Milt Sparks Summer Specials (with 1 .25 and 1.5" interchangable belt loops), and a heavy Milt Sparks 1.5" belt.
The holster I have not tried but which is getting rave reviews is the Super Tuck Deluxe.  It looks big, but the many reviews say it's the best they've used.
http://www.crossbreedholsters.com/IWB/tabid/56/CategoryID/1/List/0/Level/1/ProductID/1/Default.aspx?SortField=ProductName,ProductName
Str8shooter
Loganville, Ga.
« Reply #6 on: March 16, 2011, 06:52:05 AM »
+1 on the crossbreed. Use it with my Glock model 32.
Pete
« Reply #7 on: March 16, 2011, 07:12:16 AM »
Arriving at a successful concealed carry compromise is usually a trial and error enterprise as several have pointed out.
I would completely agree with that.
That said, the only solution I found was self constructed designed to fit me, by me.  I arrived at that after buying a basket full and selling a basket full. Along the way those holsters educated me thru trial and error as to what worked and did not for ME.
And even then it took building and wearing 5 or 6 holsters to get it right.
Lessons learned:
The holster MUST fit the belt exactly. 1.75 inch wide by thick belt.
The holster and belt must be sturdy, think stiff.
The holster must be molded to the actual gun.
The gun must fit the holster snuggly.
Snug enough to not require a safety strap or other means of retention and still release the gun for drawing.
Leather worked well for me as it can be obtained in a thickness that is sturdy and can easily be molded when dampened with rubbing alcohol and drys stiff.
Two pieces of leather with the ruff sides permanently glued together in the approximate shape of the holster, 3 or 4 brass Chicago screws a small length of leather lacing, a bottle of alcohol, a sharp knife, leather punch and some leather glue is all that is necessary. Of course some time and thought and trial and error.
I have been wearing my last design daily for 10+ years, it is so comfortable I forget I have it on and no one has ever said anything about observing it. Strong side, outside the belt carry with shirt out or vest or jacket with a 24 oz 45 Colt Auto.
My basic design seems to work well for several of my friends as they are now using the same concept. That is not the say it would work well for you without some changes and experimentation.
When building one for a new gun or person it usually still takes me two tries to get it right.
So experiment. If you decide to proceed this way let me know and I will send you a starting pattern and advice.
JimC
SE Wisconsin
« Reply #8 on: March 16, 2011, 10:12:20 AM »
sugarbear,
I have also been looking for a concealment holster that will fit my not so petite body. Although not quite as large as you, I have the same issues. While talking to a friend that is my size that always carries, he reccommended a t-shirt holster. They are expensive, but I found a place that sells just the holster patch in order to try the concept at a mild cost.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=160484893268&var=460010289852&ssPageName=STRK:MEWNX:IT
I am not going to give my aproval on it yet, I bought a couple of them to see if it is as comfortable as my buddy says. You sew the holster on a T-shirt yourself, (or your significant other does). It does make sense to me, but only time will tell.
I also just purchased this,
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180490804985&ssPageName=STRK:MEWNX:IT
it is designed to be a conceal in plain sight type of holster, but it is only good for smaller weapons. It should fit my Kel-Tec PF-9 well, I have not received this yet so the jury is still out on it.
THEN AGAIN, THERE IS ALWAYS THE POSSIBILITY OF US LOOSING SOME WEIGHT SO WE DON'T HAVE THIS ISSUE, yea right.
Jim
Jim Callaghan    SE Wisconsin
« Reply #9 on: March 16, 2011, 10:37:19 AM »
I know, I know, concealed means concealed, and I might as well have a flashing neon sign over my head saying ARMED! for anyone "in the know" but, with my... physique... I finally just gave up on finding a holder that worked for me AND was concealed without printing horribly...
I went with a concealment fanny pack...
Yeah, as I said, to those in the know it's a dead giveaway, and to those NOT in the know it screams "DORK!" but I'm old enough I just don't care about that too much anymore...
It works well, I can carry while riding, I can easily access my weapon form just about any position, including while riding or driving.
Anyway, just another option to consider...
BWANA
« Reply #10 on: March 16, 2011, 12:48:46 PM »
I think DeSantis is the best value. I know the guys at DeSanits, their holsters are designed by a great team of engineers that have years of shooting and gunsmith experience.
Did I mention the owner rides a valk?
sugerbear
wentzville mo
« Reply #11 on: March 17, 2011, 08:13:46 AM »
thanks for all the replies.
guess i just have to go someplace and try out and try out several.
cabala's has a nice selection, and maybe someone to help.
MNBill
Southern Minnesota
« Reply #12 on: March 17, 2011, 11:00:33 AM »
I just saw a leather concealed carry vest in my last Cabelas flyer, they work good and do not look out of place on a bike.
MNBill
SE Minnesota
sugerbear
wentzville mo
« Reply #13 on: March 17, 2011, 11:42:29 AM »
 i saw that too  thanks
« Reply #14 on: March 18, 2011, 06:18:34 AM »
On the bike, in the tank bag, on self, crossdraw  inside the pants.  works good with a skinny guy like me.  Hoser  cooldude
paps350
Pittsburgh Pa
« Reply #15 on: March 18, 2011, 12:19:22 PM »
I agree with XRING on Blackhawk Serpa Holsters. I have tried many and have found in the waistband very uncomfortable as I am a rather robust person myself. I use the paddle option on all my Blackhawks and carry on my strong side.They are also reasonably priced.
Gangman036
Terre Haute, IN
« Reply #16 on: March 18, 2011, 10:55:02 PM »
I use this one a lot. Have never had a problem with keeping it in place. Works great under an un-tucked shirt.
http://acecase.com/belly-band-concealment-holster.html
Sludge
Toilet Attendant
Roaring River, NC
« Reply #17 on: March 19, 2011, 09:18:08 AM »
I too use a crossbreed holster.  It wears well. Im also partial to Milt Sparks holsters.  Specifically the Watch 6
I also wear a FIST K1 kydex inside/outside holster at times too.
"We have two companies of Marines running rampant all over the northern half of this island, and three Army regiments pinned down in the southwestern corner, doing nothing. What the hell is going on?"
Gen. John W. Vessey, USA, Chairman of the the Joint Chiefs of Staff during the assault on Granada
