November 22, 2025, 01:30:20 PM
Vent tube
Topic: Vent tube (Read 1340 times)
shank
Morristown TN.
Vent tube
March 17, 2011, 06:38:45 PM »
What is the tube that is connected to the kick stand on an I/S ? i have never noticed it before. until today, when i found it leaking a little gas in my drive way. I started the bike and pulled it into the garage for further inspection and it stopped. Is this normal ? any help would be greatly appreciated so i can sleep tonight. i am going on a long ride this weekend, leaving in the morning.
Red Diamond
Beaumont, Texas
Re: Vent tube
March 17, 2011, 07:17:01 PM »
I think that tube is the carberator drain tube.
GOOSE
D.S. #: 1643
Southwest Virginia
Re: Vent tube
March 17, 2011, 07:27:17 PM »
shank.....if you have drained your carburetor drain bowls lately, then that is just the little gas that is left in the lines.....mine will do this after i have drained my bowls, and it will go on for 40-50 miles afterward...then stop.....if it keeps leaking then you may have to put in new o-rings. when you tighten ou the drain bowl screws..don't overtighten, because it don't take alot of torque to strip them. have a safe ride tomorrow.
shank
Morristown TN.
Re: Vent tube
March 18, 2011, 04:08:46 AM »
Thanks for the replies. I am not sure what you mean about draining the carb bowls. I havent drained my bowls i had just got home. but i have to admit i called down on her pretty hard on the way home. I am going to ride and see what happens. thanks again.
Re: Vent tube
March 18, 2011, 05:50:58 AM »
Gas tank vent tube will drip if tank overfilled. Did you fill up just before you parked? Hoser
Re: Vent tube
March 18, 2011, 06:59:35 AM »
Quote from: 99 Red Diamond on March 17, 2011, 07:17:01 PM
The carburator drain tube is on the right side down next to the dragon drool tube. The single vent line near the kickstand is the vent line atttaced to the tail of the fuel tank.
=> InZane XXV
