February 02, 2026, 01:47:28 AM *
Author Topic: Going to do a valve adjustment,she up on the jack,is that ok?  (Read 2106 times)
HotRod
Henderson, NV
« on: March 21, 2011, 04:48:00 PM »
  In the shop talk it says to have her on the kick stand and you will lose a little oil,is it ok to do the adjustment on the jack or will I lose more oil then if on the kick stand?
« Reply #1 on: March 21, 2011, 04:54:37 PM »
quite ok, probably lose less that way
HotRod
Henderson, NV
« Reply #2 on: March 21, 2011, 05:00:46 PM »
Cool,thanks Chris
« Reply #3 on: March 22, 2011, 06:16:14 AM »
The way to lose the least amount of oil whether its on a jack or not is lean it one way  a minute and then the other to allow all the oil to drain from both valve covers, then go ahead and take the covers off.. My floor has been rust-proofed enough over the years, enough oil gets gets on it when trying to keep it dry..
iliveforcurves
Proud owner of a 2003 Valkyrie Standard
Buchanan Dam, TX
« Reply #4 on: March 22, 2011, 08:10:38 AM »
I did the lean the bike one way then the other like Patrick said and had no problem with the bike leaning on the sidestand.  I would be careful when loosening bolts and spark plugs when the bike is up on the jack.
Live to ride, ride to...uh, what was the question again?
2007 Kawasaki Ninja 500
2007 Kawasaki Ninja 250
1978 Yamaha SR500 (not running)
« Reply #5 on: March 22, 2011, 09:01:53 AM »
there is a serious problem if the valve cover bolts or spark plugs are so tight you are in danger of "wrenching" the bike off a jack to loosen them.  I never found it necessary to remove the spark plugs to do the valves.
TearlessTom
Spanish Fort, AL.
« Reply #6 on: March 22, 2011, 09:08:51 AM »
The reason I pull my plugs  is to make the engine easier to  turn over
Westsider
Fort Worth TX.
« Reply #7 on: March 22, 2011, 06:20:46 PM »
well how did it go ,,i did one at about 35 or so k and the the thing was spot on. cooldude
HotRod
Henderson, NV
« Reply #8 on: March 22, 2011, 11:45:41 PM »
Went just fine,did it on the jack and barely lost any oil at all,25k and they were good,made a couple of very minor adjustments I think just to say I did,she's a very tight motor. Changed all my vacuum lines and fuel lines,last time I did a carb sink I found a cracked line so I replaced them all and re sunk the carbs,polished her up head to toe,about 12 hrs worth,good to go,runs beautiful to work today.
