February 02, 2026, 01:45:59 AM *
Author Topic: Need a simple delay setup for my fans.  (Read 1787 times)
Jeff K
« on: March 22, 2011, 10:04:04 AM »
Would like to
A) stagger the start up of the fans, high current draw is high when two start at the same time. brings the idle down.
B) delay the start to avoid any short cycling.
Ideas?
And I'd rather not add a second relay if I can avoid it...
Bobbo
Saint Charles, MO
« Reply #1 on: March 22, 2011, 10:16:49 AM »
I suggest an inrush current limiter.  It is effectively a resistor that lowers it's resistance to near zero after a few seconds.  This would stop a large current draw, and slow the startup of the fans.  Online suppliers like Digi-Key usually stock them (http://www.digikey.com/?curr=USD).  You will need to decide the initial resistance, and total energy that the device absorbs before going to low impedance.
Jeff K
« Reply #2 on: March 22, 2011, 10:25:27 AM »
First let me say I don't have a clue about inrush current limiting.
But if It adds resistance to slow the start of the fan, wouldn't also be drawing significant power too?
Bobbo
Saint Charles, MO
« Reply #3 on: March 22, 2011, 10:35:22 AM »
It is actually an NTC thermistor, which is a device that lowers its resistance when heated.  When cold (room temperature) is may be say 10 ohms.  When the fan relay kicks on, the thermistor will initially allow only about 1.4 amps to the fan.  As it heats up from resistance, it's resistance will lower to something like .1 ohm, which is enough to keep it warm and pass 15+ amps continuously.  Sorry for the techno-talk, but I'm sure you can understand it.
This one might work well.  I don't know the running state current of your fans, but this one is rated at 15 amps.
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=570-1058-ND
When on, it will use about 12 watts of power and will have about a 1 volt drop.  It will get somewhat hot when running, so don't let it touch anything.
« Last Edit: March 22, 2011, 10:45:27 AM by Bobbo » Logged
« Reply #4 on: March 22, 2011, 01:31:28 PM »
I use this for the viper fan installed on my dakota
http://www.spal-usa.com/fans/automated/accessories/fanpwm.html
this is their latest one.
http://www.spalusa.com/store/main.aspx?p=itemdetail&item=FAN-PWM-V3
« Reply #5 on: March 22, 2011, 03:32:23 PM »
You said multiple fans. How about a second temp sensor set a little higher, so you get one when one is only needed, and 2 when you start heating up.
