February 02, 2026, 03:24:56 AM *
Author Topic: Thread size on the fan switch?  (Read 1727 times)
Jeff K
« on: March 22, 2011, 10:05:30 AM »
Anyone know what the thread specs are on the fan switch on the radiator?
Blackduck
West Australia
« Reply #1 on: March 22, 2011, 10:37:39 AM »
Far away from the house at the moment so cannot check but 16mm sounds right and I think it maybe 1.25 pitch. Fitted a car one to the Magna. Magna's are the same as Valks and too hot for my liking.
Cheers Steve
Jeff K
« Reply #2 on: March 22, 2011, 10:58:29 AM »
Cheers Steve
I know for fact that the kid at the counter is going to ask... "what year and make is it" .  tickedoff
Blackduck
West Australia
« Reply #3 on: March 22, 2011, 11:33:35 AM »
you forgot colour and if it is darkside LoL
Blackduck
West Australia
« Reply #4 on: March 28, 2011, 12:10:21 AM »
Finally back home, checked the one I pulled from the Magna, 16 x 1.5 thread
Cheers Steve
Jeff K
« Reply #5 on: March 28, 2011, 06:10:17 AM »
Cheers Steve
Great! Thanks!
« Last Edit: March 28, 2011, 07:29:16 AM by Jeff K » Logged
Blackduck
West Australia
« Reply #6 on: March 28, 2011, 08:13:38 PM »
Honda sure designed these to run on the hot side, that switch is 100 oC/212oF. As it is on the engine inlet side that is the temperature going into the engine. Normally looking for 10-15 degree temperature rise across an normal running engine so you are looking at an engine running at 222 to 227 before the fan will cut in. The Magna was around 227-230 on the back cylinders so fitted a slightly cooler switch to it to hold the engine around 200.
Cheers Steve
