February 02, 2026, 03:24:20 AM *
Author Topic: TIMING BELT?  (Read 3775 times)
BIG--T
The Twilight Zone
« on: March 24, 2011, 06:53:18 AM »
Hi, I have a 98 Standard that I have recently purchased that had 8,000 miles. I have just put 1,000 miles and have rode it pretty hard at times, red lining her at times.
My question is should I change the timing belt because of the age? I know the manual says 100,000 miles but was wondering about the age factor considering it averaged 700 or less a year.
Thanks in advance Wink
« Reply #1 on: March 24, 2011, 07:08:18 AM »
Two things:
-Riding "hard" does not stress the timing belts any more than riding "easy"
-There are two timing belts and you should visually check them if you are concerned
Like any other belt......if they are hard, cracked, lobes missing, then they must go.....if they are in good shape physically, they should be fine for many more miles
Disco
Republic of Texas
« Reply #2 on: March 24, 2011, 07:53:11 AM »
My bike has just under 37,000 on the odometer, but almost 12 years on the clock.  They are probably fine, but I got 2 Gates T275 belts for $18.02 each from Amazon with free shipping.  I'm going to change them in the next few weeks.  Just 'cuz.
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
Black Dog
VRCC # 7111
Merton Wisconsin 53029
« Reply #3 on: March 24, 2011, 08:30:09 AM »
I'm with Disco on this one...  Less than $50, for a whole lotta peace of mind  cooldude
I did mine when the Beast was 10 years old, and at 65K.  They looked good, but now I rest easy.
Black Dog
Don't you know...
Joe Hummer
Arnold, MO
« Reply #4 on: March 24, 2011, 08:34:39 AM »
I will be changing mine out this weekend...80k on my 99 IS.  Piece of mind is work the money in this case.  +1 on the Gates belts from Amazon.
Joe
1999 Valkyrie Interstate
Ferris Leets
Catskill Mountains, N.Y.
« Reply #5 on: March 24, 2011, 10:20:46 AM »
99 I/S Had 30k on it.  I got new belts and opened it up.  The originals looked fine but since I had new in hand I changed them.  Off of the bike it was obvious that they needed changeing.  Several teeth were separating from the belt and I suspect would have come of before long.
   New belts cheap, broken on the road very expensive.  Change the belts.
BIG--T
The Twilight Zone
« Reply #6 on: March 24, 2011, 06:31:29 PM »
Thanks ya'll, I believe I will for piece of mind. Are they hard to change? After a lifetime of twins and some inline 4s, this thing is like an alien craft!  2funny
Joe Hummer
Arnold, MO
« Reply #7 on: March 24, 2011, 06:53:16 PM »
I will let you know Saturday Night or Sunday Morning... Cheesy
art
Grants Pass,Or
Grants Pass,Or
« Reply #8 on: March 24, 2011, 07:00:10 PM »
Very easy to change.Can be done in less than an hour.
just remember do not rotate the cams or the crank with the belts off.Take them off an replace them without moving anything
« Reply #9 on: March 24, 2011, 07:20:40 PM »
After removing the cover, rotate the crank with a socket. Align the marks on the cam wheels. Check both wheels and the crank marks. I believe T-1 is where you want to align that mark. It'll be obvious when it's opened up. Remove the belt tensioners and the trigger wheel pickups. Clean it all and replace belts, pickups and tensioners. The springs are suppose to properly tension the belts but I added a VERY SLIGHT bit of extra tension before tightening the bolts.
BIG--T
The Twilight Zone
« Reply #10 on: March 24, 2011, 07:59:18 PM »
With just 9k on her, you think I need to replace tentioners?
BIG--T
The Twilight Zone
« Reply #11 on: March 24, 2011, 08:02:15 PM »
Thanks Joe, let me know! crazy2
Ferris Leets
« Reply #12 on: March 25, 2011, 07:11:20 AM »
When you see how it works you can decide about the tensioners.  You won't need to change them unless they are broken.
   As to how long it will take.  Took me about 2 hours start to finish.  I really took my time looking and checking and understanding before I removed anything.  As I remember it looks like you could do the job without removing the sensors for the timing.  But they DO need to moved.  It is actually a very simple job if you follow the instructions Sandy gave.  As long as the marks are lined up when you get done everything is good.  After it is done you can forget about them for another 10 years or 100k miles which ever comes first.
BIG--T
The Twilight Zone
« Reply #13 on: March 25, 2011, 07:42:39 AM »
Thanks Ferris for the info and I also take my time especially if it's something I've never done before cooldude
RP#62
Gilbert, AZ
« Reply #14 on: March 25, 2011, 08:13:08 AM »
When you're all done, before you fire it up, pull the plugs and turn it through a couple of times by hand (rotate the crank with a socket).  If you did something wrong, you'll want to know about it before you start it up.
-RP
Ferris Leets
« Reply #15 on: March 25, 2011, 09:40:09 AM »
-RP
Not a bad idea.  I did do that because i was confident enough that the marks were aligned correctly.  On the other hand I also wear a belt OR suspenders.
I also could see this job taking .5 hr. if you had all of the tools in hand and had done it a few times.  When I changed out the POG on the Nomad  to the Ferris SOG it took about 2.5 hours the first time.  By the 4th try I could do it in about 20 minutes.
« Reply #16 on: March 25, 2011, 10:40:15 AM »
In the middle of this belt removal myself. Sounds like overkill-but i took my electronic sliding calipers and measured the length of all 10 bolts that came out of there and made a chart of where each one came from. You end up giving the stealer money on your screw up that was easily saved by doing this the first time-well actually not doing it-you become real cautious. uglystupid2 Don't ask me how i know this. tickedoff A little caution-your digital camera-and good directions can go a long way to a good outcome on doing the maintenence yourself. Good rule of thumb-you get pissed off confused or tired-back off and rethink it. It never goes smoothly the first time. 2funny Also a real wealth of information available on this board right here. Don't proceed til you have a pretty good understanding of what your getting in to. RIDE SAFE.
Joe Hummer
Arnold, MO
« Reply #17 on: March 26, 2011, 07:58:50 PM »
Ok...to put it simply...this was EASY!!!!  You do have to remove the pickups for the timing but they are indexed so you can put them on in the right place.  Right (as sitting on the bike) belt off first...then left one off.  Put them on in reverse.  The manual says to put the tensioners on before placing the belts on.  As I said...easy enough.  As for the bolts...you can tell easy enough which bolt goes where.  they will either reach or not.
Joe
