November 22, 2025, 04:36:15 PM *
Author Topic: DIY Fork Seals  (Read 1948 times)
deckerjr
Albuquerque NM
« on: March 25, 2011, 09:45:51 AM »
I try to wrench as much as I can to avoid the "stealer" and now have a fork leaking. Is there a way to replace them without diassembling the whole fork tube? I don't really want to deal with springs and stuff. After researching the boards, I found the homemade seal driver but the few links about replacing them are dead.
valk2000
columbus nebraska
« Reply #1 on: March 25, 2011, 11:09:12 AM »
I did this on my GL1800 take some film and go around the tubes and get the grit out of there work the front up and down- repeat  this a couple times-it helped me did it about 20,000  miles ago and still no signs of leaking... :cooldude:0
Valker
Wahoo!!!!
Texas Panhandle
« Reply #2 on: March 25, 2011, 12:05:38 PM »
I just replaced my fork seals. There is a good article on Dag's ValkyrieNorway.com site. It was a much easier job than I had anticipated. cooldude
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #3 on: March 25, 2011, 01:32:40 PM »
DECKERJR......THE SITR THAT VALKER GAVE IS A REAL GOOD SITE TO USE FOR THE SEAL REPLACEMENT....DAG REALLY HAS PUT TOGETHER A COMPLETE INSTRUCTION GUIDE TO REPAIR/FIX ALOT OF THINGS THAT AT TIMES GOES WRONG WITH THESE BIKES.  I THINK YOU WILL HAVE NO TROUBLE REPLACING THE SEALS.  GOOD LUCK. cooldude
deckerjr
Albuquerque NM
« Reply #4 on: March 28, 2011, 09:04:07 AM »
Thanks for the input. I tried the film trick months back but I think I only went up through the dust seals. How far do you work the film in to get to the actual seals?
« Reply #5 on: March 28, 2011, 09:10:51 AM »
Far enough to get a fair amount of oil flowing down the tube.
deckerjr
Albuquerque NM
« Reply #6 on: March 28, 2011, 10:41:37 PM »
Thanks Willow, I tried again and got it flowing and rode to work and it seems better. We'll see!!!
