March 22, 2026, 06:24:06 PM *
Author Topic: Time for some new shocks....  (Read 1594 times)
Stanley Steamer
Athens, GA
« on: March 25, 2011, 03:56:40 PM »
I ride alone 99% of the time...I've only had to ride folks on the back of the bike a few times.....I do pack the trunk on the I/S full when I go on a long ride, just not the same thing as having a passenger on the back.....
I was wondering if the Progressive 412HD's would work ok instead of the pricier 440's??......and I can't remember if the OEM shocks are 12", 12.5", or 13" stock??....I hate to spend a lot more $$ for something that won't help me.....anything would beat the OEM's I have now with 84,000 miles on them......
I'm thinking that I also need to change out the two timing belts for piece of mind..... cooldude
Stanley "Steamer"
"Ride Hard or Stay Home"
Ramjet
Have Valk, Will Travel!
Buford, GA
« Reply #1 on: March 25, 2011, 04:22:27 PM »
Stanley,  have you thought about dieting?   2funny  2funny  2funny
Ride more; talk less
Stanley Steamer
Athens, GA
« Reply #2 on: March 25, 2011, 04:25:51 PM »
Yeah......thinking about it doesn't help though!!..... Cheesy Cheesy.....Ride to eat, eat to ride....or sum'n like that!!...... cooldude
Stanley "Steamer"
Crazyhorse
Hattiesburg, MS
« Reply #3 on: March 25, 2011, 05:05:00 PM »
The standard shock is 13". I have ran the 412HD on both my Standard and IS and they have done a good job. I have 11.5" on the Standard and 12" on my IS.
for the money you can't go wrong.
Warlock
Magnolia, Ms
« Reply #4 on: March 25, 2011, 05:14:57 PM »
I wouldn't use the 412's. It cost more, but I would go with the 440's or either work shocks. I put 13" 440's on my Tourer (halfbreed) and wished I had put the 12 or 11 1/2's.
David (Warlock)
Tropic traveler
Silver Springs, Florida
« Reply #5 on: March 25, 2011, 05:15:13 PM »
Stanley, I have a pair of stock length 412's with around 12,000 miles on them. One of them started to leak so I took 'em off & put a set of I/S shocks back on.
I did like the way they rode for the year they were on. Naturally they started to leak one month out of warranty! Angry
Anybody got a spare single 412 they want to part with??? Shocked
BTW, they are the HD model.
'13 F6B red for Kim
Stanley Steamer
Athens, GA
« Reply #6 on: March 25, 2011, 05:18:12 PM »
So, if I ordered a 13" 412HD, then it'd probably be ok for the I/S since I don't ride 2 up?.....
I'm not saying that anything is wrong with the OEM's, but surely 80,000+ miles and 11 yr old shocks couldn't be as nice as sone new ones?.....
I was planning on measuring the OEM's from centerline to centerline of the bolt holes....just wasn't sure if the stock length is with them off the bike?....
Stanley "Steamer"
Crazyhorse
Hattiesburg, MS
« Reply #7 on: March 26, 2011, 06:52:55 AM »
The length of the shock is a preference it's the Heavy Duty part that you need for the added weight. I have not ran the 440's so I can't make a comparision but the 412's work well and I have had the ones on the black bike for four years with no trouble. I'm running darkside (205/55/16) with 11.5" shocks no problems.
Odessa my I/S seen below with 11.5" 412's but I prefer the 12". cooldude
« Last Edit: March 26, 2011, 06:57:36 AM by Crazyhorse » Logged
« Reply #8 on: March 26, 2011, 07:34:59 AM »
If you get 13s and can still reach the ground easily (I can reach the ground plenty easy, 30" inseam)
you'll drag less than with shorter shocks...
-Mike "I'd think..."
Probie (Scooter57)
Auburn Georgia
« Reply #9 on: March 26, 2011, 09:21:31 AM »
I have 412's in Heavy Duty on mine, been on there for 3-4 years (I don't remember), but they have worked fine. Next time I replace them I will get the longer version so hopefully the dragging while riding 2 up will stop.
Sorcerer
Brooklyn Center MN.
« Reply #10 on: March 26, 2011, 01:22:12 PM »
When I replaced my OEM shocks on my Standard/tour I went with the 440sHD, at 13". My inseam is 29". Long and short of it is 440HDs have far less spring sag than the stock 13" length Honda shocks. It took a bit to adjust to the added hight. If I had to do it again I would get the 440HD.in a 12 1/2". My original plan was for 2 up, pulling a cyclemate trailer. Wife messed up her back and can no longer ride with me. I now run the shocks at 2 turns out from the softest setting and I can still get the pegs to talk.
MacDragon
My first Valk VRCC# 32095
Middleton, Mass.
« Reply #11 on: March 26, 2011, 01:32:06 PM »
I put 11.5" on my standard ... 412s    they are just fine and can flatfoot with room to spare @ 5'8" and 30 inseam.
Patriot Guard Riders
Stanley Steamer
Athens, GA
« Reply #12 on: March 26, 2011, 04:29:05 PM »
I am 5'8" with a 30" inseam and I can flatfoot the I/S like it is......I'm leaning towards the 412HD's in the stock 13" length..... cooldude
Stanley "Steamer"
