September 15, 2025, 04:00:33 AM *
Pages: 1 [2]   Go Down
Author Topic: DOES EVERYONE HAS CARB PROBLEMS?  (Read 7178 times)
BIG--T
The Twilight Zone
« Reply #40 on: March 28, 2011, 06:02:42 AM »
Most carb "problems" are probably caused by vacuum leaks.  Syncing carbs is just a maintenance procedure; takes about 45 minutes max and most of that time is setup and buttoning up afterward.
Vacuum leaks wouldn't be a problem, but syncing and rebuilding carbs is something I'm not familiar with and there is no one in my area that  is knowledgable  with Valkyries. Even a guy at the Honda shop didn't seem to know what a Valkyrie was!! Cry
highcountry
Parker, CO
« Reply #41 on: March 28, 2011, 07:34:38 PM »
For a carb sync, I use a Twinmax Carb Synchronizer and it makes for an easy DIY job.  And if you have other buddies with multi-carb bikes, you can share the cost.  There might be other cheaper places to buy one but Google found this one.
http://www.rlmotorcycles.com/cgi-bin/eShop/index.cgi?cart_id=1286449051.43130&pid=582&product=TwinMax
BIG--T
The Twilight Zone
« Reply #42 on: March 28, 2011, 07:50:42 PM »
Thanks for the heads up, I didn't know they made anything like it. The way you talked about sharing the cost, I thought it was big money! lol No all by buddies have V-Twins, mostly HDs, I'm the  only one with 6 cyls.! Grin
Pages: 1 [2]   Go Up
