November 22, 2025, 04:40:00 PM *
Author Topic: Shifter oil "leak"  (Read 3156 times)
BudMan
"Two's in."
Tecumseh OK
« on: March 27, 2011, 07:24:54 PM »
I have a very slight leak from my shifter.  It is not really leaking, just weeping enough to make a mess on the side of the case.  After setting for several days, enough oil will come out to finally drip on one of the header pipes.  Is there a seal of some kind around the shaft?  How much work is it to replace?
Buddy
Tecumseh OK
MOOT# 263
VRCC # 30158
1948 EL Harley
2013 F6B Delux
« Reply #1 on: March 27, 2011, 07:28:55 PM »
Check this out...
http://lifeisaroad.com/valkshiftseal.html
« Reply #2 on: March 27, 2011, 07:29:37 PM »
this has been thoroughly addressed a couple times in the last week or so, so Im not going to get into all the details.  Easy to change.  Order a seal.  While you are waiting for it to come in, clean the mess up, get rid of the evidence VALKYRIES DONT LEAK OIL and then after its really really clean tap the seal in tighter with a smooth blunt object like the handle end of a small scrfedriver.  If you get the seal to seat back into its seat it wont leak again for a long time
« Reply #3 on: March 27, 2011, 07:30:11 PM »
Yea a small seal in there. There is a post a few down about it. Daniel Meyer has a great write up about it. Its really simple his way.
BudMan
"Two's in."
Tecumseh OK
« Reply #4 on: March 27, 2011, 07:46:42 PM »
Found it!
Thanks guys.
Buddy
Tecumseh OK
MOOT# 263
VRCC # 30158
1948 EL Harley
2013 F6B Delux
« Reply #5 on: March 28, 2011, 07:07:20 AM »
Before removing the shifter linkage find some way to mark it so you get it back on correctly.
Many threads here on the problems of shifting only to find the linkage has been replaced incorrectly.
A picture might be the way to go!
« Reply #6 on: March 28, 2011, 08:07:54 AM »
No need to mark it....there is already a punch mark for proper alignment.  That punch generally goes in the space between the clamping jaws of the mount.  just look if its offset how much, visually one tooth either way will look very different so its cake to get it on the same position if you are looking
valkyriemc
NE Florida
« Reply #7 on: March 28, 2011, 03:58:54 PM »
If you don't get it right, you'll find you real quick when you ride off. Ask ask me how I know...
« Last Edit: March 28, 2011, 04:01:45 PM by valkyriemc » Logged
Veteran USN '70-'76
