February 02, 2026, 03:18:12 AM *
Author Topic: gl tranny........  (Read 1951 times)
rick_in_vanc
Vancouver WA
« on: March 27, 2011, 09:37:47 PM »
question:
The final drive gear ratio for the Valkyrie is 2.833 from what I have found in 5 different sites..(though I don't have those site available at the moment) I also found that the goldwing has a 2.75? final gear ratio, and different 4th and 5th gear ratios..wonder if they'll interchange??
"what ever ya are.......... Are it good" ~Ed 'Big-Daddy' Roth
X Ring
VRCC #27389, VRCCDS #204
« Reply #1 on: March 27, 2011, 10:58:39 PM »
Probably and with the slightly higher rear end gear ratio lower your rpms and increase your mileage a little bit.
Marty
Sodbuster
« Reply #2 on: March 28, 2011, 04:08:47 AM »
That would be quite an undertaking thou (time and $$) to gain a few MPG .... especially the trans.
I doubt it would be worth it.
VRCC # 30938
X Ring
« Reply #3 on: March 28, 2011, 05:31:05 AM »
I wouldn't do it just to do it but if I had to tear it apart anyway and could find the parts reasonably, I might just go for it.
Marty
Bobbo
Saint Charles, MO
« Reply #4 on: March 28, 2011, 07:21:38 AM »
The ratio difference is less than 5%.  That would be a lot of work for very little (if any) gain.
« Reply #5 on: March 28, 2011, 08:00:19 AM »
I've posted info on this before including all of the gear ratios, suggest a search.
but quickly, '97 and later GL 4th and 5th gear sets interchange with the valkyrie, before '97 they do not, due to different size shafts, this is from what I have read.
It has been posted before that the rear Diff gears are not interchangable.
rodeo1
« Reply #6 on: March 28, 2011, 09:29:36 PM »
if my memory is correct (and i'm old) the valk final drive is on the right side and the wing on the left ?????????
rick_in_vanc
Vancouver WA
« Reply #7 on: March 28, 2011, 09:37:15 PM »
food for thought as I found a wrecked gl1500 for pennies on the buck
« Reply #8 on: March 29, 2011, 06:07:56 AM »
sounds like a good short block swap project for u.  Smiley
