March 22, 2026, 08:15:34 PM
Anybody had speedbleeder problems?
Topic: Anybody had speedbleeder problems? (Read 1305 times)
ArmyValker
Richland, MO
March 29, 2011, 02:27:10 PM »
I took an opportunity to flush my brakes and clutch a few days ago, and decided to throw in the speedbleeders I bought last year. The brakes worked fine, but the clutch would not bleed with that thing in there... had to bleed it like a regular bleeder... I assume the one way valve is leaking.
Anybody else had that problem, or am I just an idiot?
Bobbo
Saint Charles, MO
Re: Anybody had speedbleeder problems?
March 29, 2011, 02:36:44 PM »
I'm guessing the speedbleeder needs more pressure to overcome it's internal spring loaded ball valve than what is needed to compress the clutch springs.
March 29, 2011, 02:46:10 PM »
It was many many many years ago when I put mine in, but I remember there was SOMETHING that kept me from using the speed bleeder on the clutch, I finally gave up on using that one, but do use 'em for the brakes...
T.P.
Apple Valley, Minnesota.
March 29, 2011, 03:05:24 PM »
I have speed bleeder's on the brakes and the clutch, no problems. T.P.
You did use a SB8125LL for the clutch didn't you?
http://www.valkyrieriders.com/ShopTalk/speedbleeders.htm
Last Edit: March 29, 2011, 03:14:26 PM by T.P.
Valker
Wahoo!!!!
Texas Panhandle
March 29, 2011, 03:09:31 PM »
Can't use speedbleeders until the lines are full. Fill it with a MityVac and then the speedbleeders should work fine.
ArmyValker
Richland, MO
March 31, 2011, 01:22:17 PM »
Hey, appreciate it guys, I did use that SB8125LL bleeder for the clutch, but still no dice. I'll try to fill the lines with a pump next time.
9Ball
Reply #6 on:
March 31, 2011, 01:59:35 PM »
they have great customer service. call them, explain the problem, and they will probably send you a new one no questions asked. I had a bad one a few years back and it was replaced within days no charge.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
