November 22, 2025, 04:33:07 PM *
Author Topic: Shaft has play?  (Read 1272 times)
BIG--T
The Twilight Zone
« on: March 30, 2011, 08:05:42 PM »
Does the shaft coming off the transmission that connects to the shifter suppose to have play in it?
I am trying to put on a Rattlebars shift kick and it is aggravating! I must not have the o rings and washers just right. Anyway when I went clockwise a tooth and started to tighten the shifter, that when I noticed it.  I sure hope that's normal.  uglystupid2
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #1 on: March 30, 2011, 08:15:29 PM »
XGUY.....that's normal.  finish putting the rattlebars on...good luck.
BIG--T
The Twilight Zone
« Reply #2 on: March 30, 2011, 08:24:31 PM »
Whew, thanks Goose! I just knew i might have done it! Thanks for the well wishing, I'll need it! I wished I had a simple diaghram how it goes. I pot on the o rings and other washers and see I screwed up the brass one tickedoff tickedoff
Thanks Goose
PAVALKER
Pittsburgh, Pa
« Reply #3 on: March 31, 2011, 08:37:41 AM »
You will love that Kick Shift....  I had to get one for mine years ago because I was loving the heel/toe shift on the Retro.    Did you get a new one from Rattlebars or ?
John
BIG--T
The Twilight Zone
« Reply #4 on: March 31, 2011, 09:44:32 AM »
Hi John, I got it off the board and Rattlebars has closed down. I'm sure I'll love it because I'm so used to that laid back position on my Retro. I swith back and forth from the two and the key is on the opposite side on the Valk and always being consious of my toe shifting- sometimes I find myself kicking the air!! 2funny 2funny
